Daily update:
It was mostly overcast all day so the piping was extremely uncooperative in forming coils when I got home. Its going to rain and snow tomorrow, followed by a high of 41 on Thursday with 18mph winds. The coiling will have to wait until this weekend when the wind calms down and the sun will be out.
With nothing else to do, I shimmied around the crawl space to measure the runs length. At 35 feet or so each way, its a bit longer than expected. There won't be enough left over R4 pipe insulation, so I'll have to buy some 3/8th wall R1.9 stuff. I'll use it in the "vertical" run into the middle of the house. The better insulation should go on the "horizontal" run along the side of the house where there will be more wind. I never found strong enough siding to seal off this hill side crawl space. The heavy winds here knocked a tree onto the previous incarnation of this house. I might as well get on with placing cinder blocks and reap the energy savings.
Finishing the crawl space plumbing is now my top priority. I picked up three 1/2" compact valves and four 3/4" ones from harbor freight tonight. With those in hand and the measurements recorded, I'll be able figure out everything else I need to buy at Lowe's tomorrow.
The in-line temperature sensors will somewhat hold up 100%ing the in-house sections of the loop. They're going to be mounted in 1/4" copper tubes, then inserted into 1/4" compression fittings, which will screw into a T. Actually, that's a horribly expensive way to do it fitting wise. It makes securing the water temperature sensors on the inside of some insulated tubing much more tempting!
Finishing the house section of the loop this week and then doing the coils this weekend seems like a realistic plan. I'm really looking forward to testing the flow of dual ddc 3.2s pushing the complete loop (minus the future pits depth of course).
