Is it possible to mount a 240mm radiator in the top without having to cut into the 5.25" bays?
EDIT: You can't.
Can you give me (as accurate as possible) a measurement of the area inside the front of the case where you have your radiator mounted? The inside width, side to side? If you can, please measure inside the folded up side in the front, because every mm counts. Lian Li's site says it's 279mm wide and my radiator is 277mm and I'm worried it won't fit.
