Seams the have a core-voltage bug, at least the cpu-z_1.56-64bits-en.zip on my ES-chips.
http://img.techpowerup.org/101026/Capture040.jpg
24v on Core
http://10pix.ru/img1/2120/2623599.th.jpg
Hum indeed a nice one.
Can you please send the TXT reports to cpuz[a]cpuid[dot]com ?
thanks.
with the new cpuz 1.56 version from 23.45 o clock the field is grey
look
http://www.abload.de/img/zwischenablage01xhvf.jpg
dump sended
Got it, thanks.
I think I fixed the problem.
So another "glitch", but that time it was made on purpose : in that version I had to remove the VCORE report on ROG mainboards (as yours Fire4Wire).
This is of course temporary, we had to do that because the concurrent accesses to the ROG chips caused troubles. We work on a fix with Asus, and I will release a sub-version just to restore support for ROG (and that time a clean one).
thx can you send me the fixed version to my email adress when you finished it pls
the funny thing is that 1.55 reads my vcore correct
http://www.abload.de/img/zwischenablage01ugqq.jpg
1.56 doesnt
any news ranck
new beta for rog bords
and where is the cpuz forum
link?
CPU-Z 1.56 -update 18.12.2010
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.56-setup-en.exe
CPU-Z 1.56 -update 26.12.2010
https://dl.dropbox.com/u/4668167/cpuz%201.56.zip
System information tool CPU-Z has received a new update to get full support for Intel's incoming Sandy Bridge processors and the flagship P67 chipset. The 1.56 release also adds Core i7-970 support and improved Phenom II, Athlon II and Sempron II recognition.
CPUID Reviewer Kit for Intel Sandy Bridge
http://www.cpuid.com/medias/files/so...viewer_Kit.zip
For all who will review the new Intel Sandy Brige processor line, we've released a kit that includes some of our tools, plus a version of AIDA64, all updated for the new processor line.
The kit includes :
- CPU-Z 1.56.1
- HWMonitor 1.17.1
- TMonitor 1.03.1
- AIDA64 Extreme Edition 1.50.1200
Noticeable features are :
- Sandy Bridge cores temperature and power meter (HWMonitor)
- Improved clock report (CPU-Z)
- Turbo activation / remove (TMonitor)
- Support for UEFI BIOSes (all)
- AVX accelerated benchmarsk (AIDA64)
CPU-Z 1.56.1
-update 02.Jan 11
http://www.fileden.com/files/2009/12...uz%20156.1.zip
CPU-Z 1.56.2 Beta
http://www.fileden.com/files/2010/4/...uz1562beta.zip
CPU-Z 1.56.3 Beta
http://www.fileden.com/files/2010/4/.../cpuz_1563.zip
Thanks Franck and :bday:
CPU-Z 1.56.3 Beta
http://www.filehorse.com/download-cpuz/download/
-add Max TDP
-25.Jan 11
When i launch cpuz.exe (1.56.3) there's loading screen and after a while the file disappear from hdd and nothing happens.
Downloaded from different sources, 1.56.2 works perfect.
Wtfx?
ath > check your pm please.
ROG CPU-Z 1.57.1
http://www.cpuid.com/medias/files/so...asus_setup.exe
Asus and CPUID are glad to offer you a version of the CPU-Z utility with the ROG look and feel. We hope that you will appreciate that very special version of CPU-Z.
this works for my asus p5e :D
thanks stasio
CPU-Z 1.56.4 Beta
http://www.fileden.com/files/2009/12.../cpuz_1564.zip
CPU-Z 1.57
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57-setup-en.exe
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57-32bits-en.zip
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57-64bits-en.zip
* Intel Xeon "Westmere-EX" support
* GPU frequency report on Intel Sandy Bridge processor
* AMD Zacate/Ontario processors support
* Report TDP on main page when available
* Cores clocks on floating menu
* P67/H67 stepping report
CPU-Z 1.57.2 -for Asus
ftp://ftp.asus.com.tw/pub/ASUS/misc/...asus_setup.zip
My Dr.Web 6.0 ant-virus software detects a virus in the setup file.
http://img818.imageshack.us/img818/706/virusdk.png
Uploaded with ImageShack.us
CPU-Z 1.57.1
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57.1-setup-en.exe
-fix bug for Gigabyte B3 boards.
-added"Dual Channels" notification
CPU-Z 1.57.1-updated 20.04.2011
http://dl.dropbox.com/u/4668167/cpuz_1.57.1.zip
