I get them directly from the manufactor, they aren't for sale official (yet)
Wait??
does it says 5000 RPM ??
You might wanna secure the PC to the ground....
How many watts are these fans? Wonder if any fan controller on the market can handle them. I want some.
Update 2
Still no good new camera so again some pictures from my phone
Backplate (no cut-outs for PSU and Fan on photo)
http://i757.photobucket.com/albums/x...6/SNC00098.jpg
Corners cut
http://i757.photobucket.com/albums/x...6/SNC00100.jpg
Floorboard for the middle section without cuts yet (have to size up the radiator before cutting)
http://i757.photobucket.com/albums/x...6/SNC00099.jpg
Chassis on 11/02
http://i757.photobucket.com/albums/x...6/SNC00105.jpg
http://i757.photobucket.com/albums/x...6/SNC00104.jpg
Black bottom plate is just for fitting, will be replaced with custom one because of PSU and fan placing
12/2 new update :)
kiek m goan!!
haha looks good
How do you plan to join the 2 cases ( if not already done) ? I can't really judge by the photo...
^ x2.. *lurks*
I like the way it's coming out. :D
Update 3
Today i did some small fitting work, don't mind the gaps etc, this is just for checking if everything fits as i want it.
I also have to look for the CoolerMaster, the one that stays is the bottom one i think.
And there is one thing i have to look at before end molding.
Stock
http://i757.photobucket.com/albums/x...6/SNC00106.jpg
http://i757.photobucket.com/albums/x...6/SNC00107.jpg
Cut 1
http://i757.photobucket.com/albums/x...6/SNC00108.jpg
Cut 2
http://i757.photobucket.com/albums/x...6/SNC00109.jpg
Cut 3
http://i757.photobucket.com/albums/x...6/SNC00110.jpg
Stock
http://i757.photobucket.com/albums/x...6/SNC00113.jpg
At this moment
http://i757.photobucket.com/albums/x...6/SNC00114.jpg
Looking awesome, going to be a monsta!
Nice looking case there.
Teaser pic for today's update
Before Epoxy (used tape for the photo), you can see i choose to remove te top logo, bottom one still one for now (maybe i remove that one also)
http://i757.photobucket.com/albums/x...6/SNC00115.jpg
LOL, I was just going to say why two badges. I say keep the bottom one, gotta give at least SOME credit to the original case designer. Keep the pics coming, looks great. Be cool to see a pic or two of the CNCing process too. Do you do that on site or send it out?
all the CNC work i do myself, i'll upload those later on in this log. The bottom logo is staying on, otherwise the front looks to long (breaks it up a little bit)
Where are you putting the Quad radiator?
The radiators will be from the EK Waterblocks XT series, the rest is correct :D
what did you render with, btw?
What voltage are those fans?
You make me cry at what I wish I was oing with my silly looking HAF 932 ^_^
nice work!!!!
Small Update
Been busy with the front part, molding all the pieces with the use of Epoxy into 1 solid piece :), still some small work to do on it
Fitting side bar
http://i757.photobucket.com/albums/x...6/SNC00121.jpg
Test fitting with some Epoxy
http://i757.photobucket.com/albums/x...6/SNC00124.jpg
Epoxy back
http://i757.photobucket.com/albums/x...6/SNC00125.jpg
Round 1 filler
http://i757.photobucket.com/albums/x...6/SNC00126.jpg
After the second round of filler and a layer of primer, still have to do the sides (you can see the Epoxy on the sides) and then details on the solid piece :D
http://i757.photobucket.com/albums/x...6/SNC00128.jpg
This is looking really nice. Can't wait to see it cleaned up and attached to the case :up:
perfect! you're crazy!!
Updates?
Great job man, did you buy the second front part of the case directly to Coolermaster?
@ nlancaster: This weekend i will update the topic with the progress and pictures
@ Kipow: Yes, all the parts i need are sponsered by Coolermaster
