http://img38.imageshack.us/img38/1070/cpuproto32.jpg
http://img707.imageshack.us/img707/7...proto31.th.jpg
Nice.
:up:
WATERBLOCK OC E6600@ 3.510MHz, 1.52V
LOOP:
Black Ice GT Stealth 240 - MCP655™@12V - Prototype CPU LGA 775-1366
Temperatures:
Room temperature:....... 33°C
Water temperature:...... 35°C
testing good or bad?
Really good looking block. Which tool did you used to cut the micro channels? Cnc with a reaaally thin cutter?
Your plating looks really good! Could you say how you set it up? Things like concentration of nickel, voltage, etc... I have a 5,000ppm solution of nickel and I want to plate some stuff to practice for a GPU block plating in the future.
Even though I don't like cross comparing benches... here are Vapor's results from a Core 2 Duo and a D-Tek Fuzion
temps are kinda high
edit: damn skinnee got first..lol
that was the most impressive action shot when you originally posted cutting the channels.
Even more so now that it was hand-guided!
Great job!
very impressive... Do you think about selling price ? or only prototype.. sir?
i really interested one for shipping to Thailand ^^'
Very impressive work Jassaf :up: :clap:. can't wait to see actual comparisons to the other top blocks :shrug:
this block looks nice! and if you took your drill that you made the mounting holes with and drilled out the space in between the 775 and 1366 mounting holes it would be 775,1156, annd 1366 compatible. just a thought ;) are you planning on mass producing this block at all?? if so it would be nice to try out. honestly your temps are nit bad at aall considering 2 things, 1: your temps REALLY are not that much higher than those on skinnee labs and that was a mainstream top end block back then, and 2: your ambient temp is 10c higher than those tests! meaning your block runs close to the same as the fusion V2 if not better probably more comparable to an ek supreme or appogee GTZ if you do the math with your ambient temps.
it is no longer a prototype, i am currently working on its final version becouse i intend to sell it. when i release the final version you can contact me anytime if you still interested.
the mounting hole can be only one (if i make just one version). as for the result of the OC we both agree. :up:
im curious about this... how thick is the base compared to others, i think that might be why temps are a bit high... i mean i hit 70C during prime with 4 cores and 1.5v under load...
it'll be nice to see this thing tested by the pros tho :) if nothing else it looks cool!
Performance: OC E6600@ 3.510MHz, 1.52V (New Test)
LOOP:
GT240 Stealth +
Tsunami_reser +
MCP655™@12V +
Prototype CPU LGA 775-1366 +
HDD Home made
TEST-1 OCCT (without jet plate):.... Flowrate: 1.93 GPM..... Room T: 28°C..... Water T_1: 30.0°C..... Water T-2: 31.8°C ......TEMP: 56°C :down:
TEST-2 OCCT (with jet plate):........ Flowrate: 1.62 GPM..... Room T: 28°C..... Water T_1: 29.5°C..... Water T-2: 31.0°C ......TEMP: 55°C :up:
without jet plate http://img21.imageshack.us/img21/565...672515m.th.png with jet plate http://img714.imageshack.us/img714/9...560715m.th.png
Something Better ?...... yes sir! (where?) :eek: http://www.xtremesystems.org/forums/...82#post4327782
talento colombiano.
very nice :D
hi there guys, taking advantage of the fact that summers season is comming to its end, last night i recorded a room temperature of 25°C and this is the result:
52°C :p: :up:
http://img357.imageshack.us/img357/2366/tempprot.png
There is a NEW KING: (unofficial)
http://img85.imageshack.us/img85/8461/duo1.jpg
Performance: OC i750@ 3.890MHz, 1.28V
vs
EK Supreme HF
LOOP:
GT240 Stealth +
Tsunami_reser +
MCP655™@12V +
HDD Home made
OCCT (EK Supreme HF):.... Flowrate: 1.62 GPM..... Water T_1: 26.5°C..... Water T-2: 28.0°C ......TEMP: 61°C
OCCT (Prototype CPU):.... Flowrate: 1.52 GPM..... Water T_1: 27.1°C..... Water T-2: 29.0°C ......TEMP: 59°C......
:up: "Good bye, baby" :clap:
EK Supreme HF .... http://img96.imageshack.us/img96/9105/ek2652861.th.png .............. Prototype CPU ....http://img291.imageshack.us/img291/5...7129059.th.png
IntelBurnTest (EK Supreme HF):.... Flowrate: 1.62 GPM..... Water T_1: 26.3°C..... Water T-2: 27.4°C ......TEMP: 64°C
IntelBurnTest (Prototype CPU):.... Flowrate: 1.52 GPM..... Water T_1: 27.0°C..... Water T-2: 28.0°C ......TEMP: 62°C......
:up: "Hasta la vista, bebe" :clap:
EK Supreme HF ........http://img297.imageshack.us/img297/3...6327464.th.png.............. Prototype CPU ....http://img200.imageshack.us/img200/5...t272862.th.png
:fact:
Great job! I'd like to point out though that the the max temp in CoreTemp is not good for evaluation blocks, the average temps across all four cores over a period of time is needed for this. In your screenshot both blocks actually have an average temp of ~55.5°C.
I think I might need to have a go at this as well... make a new base with deeper channels for the Heatkiller :)
I'd be interested in bigger heat load performance, as in o/c of overvolted i7 @4.2+-4.5. Also can you add numbers for flow/resistance aswell? Congrats on beating 2degrees of champion :), 2 is a lot for current similarly performing waterblocks that have come near maximum effectiveness.
i7 test pleaseeee =)
I have new test: .
Performance: OC i750@ 4.005MHz, 1.39V
Thermal Test Round 1: OCCT
Thermal Test Round 2: IntelBurnTest
Thermal Test Round 3: CoreDemage
EK Supreme HF :lsfight: Prototype CPU LGA 775-1366
I am translating ... :(
http://img28.imageshack.us/img28/8818/vs01k.jpg
