Haha, I first read it as you don't want to give us idiots any links, I was like wtf have I said:rofl:
Thanks for the link!
Yup, you're right. Thought that 3pin was a 4pin.
Whoops!
I like how you switched from D5 discussion over to the MCP355 :D
What about EK dual tops? They are intended to be mounted in 5.25" bays in same manner as XSPC res are, correct? Do they transmit vibrations to the case, or do a better job, or simply the D5 vibrate less than MCP355?
And one fundamental question - atm I have MCP350 with EK top. I'm thinking about dualing. Would you get another MCP350 with single top, a dual top from EK or switch to the D5s (have read the thread from the original post, still have to decide about dual or single top)?
I can't clear the misconception in my head - so the D5s are more silent and DDCs have better flow and pressure, right? Then again, I'm confused about how you guys seem to favorite D5s, I'm under impression there are more D5s in your sigs than DDCs.
Great discussion, thanks.
You can't always get rid of them all, water always has a little gas dissolved in there, so pumping will give a tiny little cavition bubbles - you can cut down on it massively if you have a completely sealed system though, just put a couple of PSI of air pressure in the expansion tank.
