Thank You kgtiger :)
Maybe i make new Photos tomorrow. :D
Milling machine is unfortunately in holiday :D
Now I had to make the cut off on the conventional way.
http://www.abload.de/img/img_3525a2oq.jpg
Is that cut out in your MoBo for cableing?
If so the powder coating looks like a textured finish, very nice.
Thank you kgtiger :)
Yes it is for the 2x 8Pin CPU Powercable. I hope after powder coating looks clean :)
Fantastic work Benny!
I really like what you did with the midplate - very "illuminating" hehe
Looking forward to seeing what's next my friend, keep up the great work. :)
Thank you Charles :)
I'm glad that you like it, but your slight looks better to me :yepp:
I'll give my best!
Merry Christmas @all :wave:
Thanks man, Some TJ07 right here;)
Your skill with the camera its better! wich camera is?
Your build is excelent too;)
:up:
I have no Camera skills :)
It's a little bit luck, good light, ISO100 and no flash :D
It's a Canon EOS450D
Update:
Aquaero mount has arrived.... Thank you Charles for all :)
http://www.abload.de/img/img_3659ccev.jpg
http://www.abload.de/img/img_36620d80.jpg
Looking great! Great photography too!
We must share a common brain or something - I am basically doing the exact same build as you. :ROTF:
No Problem, are you start a Worklog?
When i can help ask me what you want :)
Not yet, I'm holding back pics for the time being as it's in the early stages (just got the case and hardware, TJ07, E760, i7 920, Dominator GT 1600, same as yours :D). Although things will start to pick up as I'm getting ready to send the case away to Charles for powdercoating and window cutting, plus a few other things.
Big thanks for the offer! I'll definately be watching this, it looks like a great build, and I absolutely love your photography!
wow, it is that famous aquaero mount :D I like it :up:
coming along great!
Nice Aquaero mount, where do you plan on mounting it?
Ah ok, sounds good. :up:
If you bring the matter to Charles, did you get the best support anyway. :yepp:
Thanks for the compliment :)
me too :)
:toast:
Thx :)
at the same places like the last murderbox
The plan has changed :D
http://www.abload.de/img/img_37603eih.jpg
http://www.abload.de/img/img_3763izk5.jpg
Oh come on now, more photo's, Please!
Very nice work what you have done by now.
I would like to know, what are those Hammond Box, at the beginning of the topic, for?
I have seen them many times seted in the inside of many cases and I can't realize what is their function.
It's like a utility tool for cases - you can use them for just about anything - concealing wires, mounting radiators, housing small PCBs, etc. All it is is a plastic box with a lid and a few screws. You can also order them in different sizes and materials - although the most widely used one for case modding is the 1591A.
Ok :)
Don't say I didn't warn you :D
http://www.abload.de/img/img_3771op86.jpg
Thank You :)
:up:
The EK Cooler looks very ugly :D
Now, I must find a company where I can let them nickel and hope after them, they looks better than yet. :)
http://www.abload.de/img/img_37851tu0.jpg
Thanks for the photos mate. :up:
But why do you need to have them nickel plated, looks like they already are nickel plated.
If I am right and they are already nickel plated, can't you just polish them up a bit, heaps cheaper.
I sure something like Brasso metal polish,http://www.galaxyarmynavy.com/item-10116.asp
Will quickly and easely bring them back to there full luster they had when brand spanking new in no time.
Will also work on perspex as well to remove the mineral build up and scale, just Test try it in a spot you can't see first to make sure.
Let us know how you go mate.:up:
WOAH, that board with the rams and the blocks is my absolute fav. combo
damn nice damn nice, hope to see a great tj07 come out of this
ketchup them !
did that with my dirty ek 4870 block, now clean like a mirror :)
ow, and keep it up!
No problem, always happy for you :D
Thanks for the tip with the polish! I tried, but the stains are still visible.
Thats a no go :)
I have found someone, who nickel my coolers very cheep.
I think that's the best.
:toast: I give my best :)
That's the new trend :D
