Same as mine :) (But memory is crap! Even stock can corrupt in more demanding games like Dirt 2 or CoJ:BiB)
One of the 1.125V ones?
:up:
Got myself also cards with stock voltage off 1.125V.
Can do 1000Mhz on 1.200V but for sake I always pick 1.250V to be sure :p .
I am currently running 1015/1430 1.33v. will post pics later
http://img705.imageshack.us/img705/8...memtweak06.png
currently testing 1040/1285..i heard that my card scales good with higher GPU clocks rather than pushing the bandwidth further..
my xfire hd5770 V1 (asus + gigabyte) @1050/1275 vgpu@1.299v:
vantage: gpu score=17883
http://img30.imageshack.us/img30/1286/p14512copier.jpg
HD5970 @ 1100MHz :)
http://lab501.ro/wp-content/uploads/...gleCard-WR.jpg
Nice Monstru :D
The two cores are clocked or just one ?
Thanks.
Both cores clocked bro. One crashed during this screenshot thoutg, that is why i have this loooong screenie, the lower part of the screen was black.
3x1000mhz @ E762:
http://img.photobucket.com/albums/v2...-120034238.jpg
This is not done on air, these are the first LN2 tests. On air I got 1025MHz on the GPU. Regarding the RAM, I do not now what to say, it seems that most HD 5970 don't go to high on that part.
1000/1175 at 1.25vcore runs fine in furmark for me ;-)
Just entered the club :hrhr:
3DMark Vantage
ORB - Compare
[hwbot] result detail. - hwbot.org
CPU @ 4.4GHz
GPU @ 1000/1220 @1.252V
http://img12.imageshack.us/img12/923...ucovantage.jpg
Just 24/7 run with new 9.12
21138
http://img15.imageshack.us/img15/932...1370912.th.jpg
Accelero S1 + 2*92mm NB fans 1200rpms
1.25v 1030/1370 on HD5850 Sapphire
Here is mine it is a Sapphire HD5770 with Asus top bios and it is wc cooled and there is some capmods and max volt in AF wich is 1.4v measured..
Gonna hard mod it soon and go higher..
http://i438.photobucket.com/albums/q...age57702-4.jpg
CF HD5770 V1 @1050/1350:
gpu score 19k+
http://img685.imageshack.us/img685/3...5128copier.jpg
Tried to break 20k in 06 i guess ill have to wait until i get a proper setup. Basically I'm running the crappiest possible setup,
all i have now is a stock HSF and a $20 dollar case. I wouldn't be surprised if cpu was throttling during the benchmark. The Memory i was running was G skill eco's @ 2000 8-10-9-24, I believe those were the timings.
Anyway i'll get 20k next week when i get Win 7 and some ramsinks and a decent case.
XFX 5770 V2 @ 1033/1400, I5 was at 3.6ghz. Maybe i'll go a little more Suicidal tonight and try to break 20k.
@skugpezz
what is that little gadget that let you see the temp of shader of your 5770 ?
I tried, i guess i just need better cooling. I better stop before I light something on fire.
- 5850 CF :
http://img193.imageshack.us/img193/9746/10801300cf.jpg.
- 5850 CF + GT240 DDR5 (as PhysX) :
http://img197.imageshack.us/img197/150/cfgt240physx.jpg
Thought I'd join.
Sapphire 5850 all stock using the MSI Afterburn "unofficial overcloack" mod.:p: running vantage now will add in a sec.
Fur
http://3800z24.info/Phenom/965/1ghz-5850-Furmark.jpg
3d06
http://3800z24.info/Phenom/965/3dmar...850-single.jpg
I couldn't break 18000 in Vantage. My water setup just doesn't have it.
Orb Compare
http://3800z24.info/Phenom/965/Vanta...850-single.jpg
Here's some stability test of -(below)
http://img693.imageshack.us/img693/8131/1001081.jpg
Flashed to ASUS & MX-3 in between with catalyst 9.12 hotfix
http://img85.imageshack.us/img85/3955/furmark281209.jpg
First ever got it stable @ v1.187 as shown in SmartDoc
FurMark does recognize OpenCL ,its showing 3.2 perfect........ before with cat 9.11 used to show OpenCL 2.1...............
