That has nothing to do with what I asked...
internally identical? oh yeah...sasha did review the hx1000 vs the antec on the 12v rail..the antec held 12v @ 11.96v while the hx1000's 12v was @ 11.76..
this clearly shows the weakness of the hx1000..above 1000w..the 2 500w independent power supplies are kinda...trying hard already regulating the v1 and v2 rails...
also jonnyguru tested the hx1000...Quote:
Testing with the Corsair HX 1000w and Intel Skulltrail proved quite difficult because I had used three GFX cards and as this Motherboard has two EPS 12v connectors this only left me one on the PSU as I had used all other spare ports, so had to do a make shift bodge job of joining the two EPS lines on the board first. So to start off with this would be asking a hell of a lot from the single EPS line of the Corsair unit. It dealt quite well considering though, as it provided me with a stable overclock of 4048MHz with three overclocked cards drawing a total system current of 1043Watts from the mains outlet of which 36.4Amps was coming from the EPS 12V lines. The Idle EPS 12V voltage was measured 12.06V sagging to around 11.76V under full load conditions (so a full load drop on the 12v line of 0.3v).
http://www.jonnyguru.com/modules.php...Story2&reid=89
http://i24.photobucket.com/albums/c5...25/xssss-1.jpg
http://forum.nexthardware.com/galler...2_IMG_0118.JPG
http://forum.nexthardware.com/galler...2_IMG_0115.JPG
http://forum.nexthardware.com/galler...4_IMG_0106.JPG
http://forum.nexthardware.com/galler...2_IMG_0110.JPG
Classi + 920 4500 1.53V
P55A-UD7 + 870 4500 1.61V
4 X 5870 1000/1200 1.31
+ 260GTX + 1 X 5770 Default
Stressed all vga's and cpu with Vantage and 06 and wprime, sandra
never restart,shot down
Great Work Antec :up:
I dunno about you guys, but I really think the re-made 24 pin connector is a great idea.
I hate pulling normal ones out...
Not mentioning the obvious power overkill - numbers speak for themselves! :up:
koolance 1700w watercooled psu
maby just a bit better than this :D
hiwa bro, THAT is the way to go, good job!
Jeez hiwa, that's intense :D
I know it's off topic, but which SS are you using?
Im about to buy one to replace my TX950 ;) :)
