Looking good there Miller, thanks for your info earlier about batch numbers.
NP, thanks to you too.
:up:
Another small update.
Seems the HK is getting dropped for the Swiftech XT. The socket 1156 mounting kit didn't make it in with Gary's order. I ordered it from CrazyPCs, a local shop for me, so I should be to pick it up in the morning and include it in some photos this weekend.
nice picīs millertime359
would like to see more pics to have a guide in building muy rig
I sold my MIIIF to my cousin and purchased the same board you have
my set up:
EVGA P55 FTW
Core I5 750
2x 8800 GTX (for this moment waiting 5000īs ATI crossfire )Iīm been running SLI for 4 years!!!! Grrrrrr!!!!
Mushkin Extreme DDR3 1600 4GB 2x2GB i5 Edition 7-8-7-20
WD Velociraptor 150 GB
Xilence 1000w modular
antec 1200 or custom case(home made aluminium)
Watercooling stuff
Swiftech XT
2x EK 8800 GTX FC block
Swiftech MCR220-QP and Thermochill 3.120
Typhoon III w/MCP 655
Feser tube 1/2 ID 3/4 OD
Distiled Water and silver
Bro i have same case as you. I can install 3x120mm radiator without any problem?
i think he refers to cosmos 1000
Um you are acturally the first one I see who put a evga p55 on work. Nice board as they always do. Looking good so far
Has there been any testing/comparing of the XT block with the heatkiller or other blocks?
Pretty comprehensive & professional review, including the XT @ [Review] Round 2 Overall Comparison Thread - Core i7 Waterblocks
Thanks liguhy. It is only about a degree better than the HK. I'm getting it because I couldn't find the mounting kit for the HK to convert it over to socket 1156. Seeing I was stock with getting a new block, decided to go back to Swiftech. :) ( I probably could have tried modding it, but I don't really have the tools to do that here.)
Yea, it might work out better than the HK with the way I plan to route the tubes. :)
I'm pretty certain I have the second Core I5 build log here and IIRC The Rooster got an Asus board. So I may be the first P55 FTW build log. Not a big deal though. :)
Thanks Liguhy for that link, much appreciated there mate.
Update Time! :D
I picked up the Swiftech XT from CrazyPC yesterday and it is a great looking block. Gabe has decided to slot the hold down plate so that the only thing you will have to change is the backplate when moving through the different socket designs. Nice touch. :up:
The photos really don't do this thing justice. It is a great looking block. The adjustable inlet is also a nice touch. You can see why the temps are less in alt config though as it is a bit more restrictive. Two 45s seem to fit fine though, so that is what I will probably end up doing.
Lets see what we can do for some photos.
First, Here is my little helper.
http://i621.photobucket.com/albums/t...9/P1000375.jpg
Seems he is a little preoccupied atm. ;)
http://i621.photobucket.com/albums/t...9/P1000379.jpg
The only nice thing about Fall here in MI. The trees start turning and it is really pretty. As you can see it not a great day here today though. :(
I guess it gives me an excuse to stay in and work on the build. :D
http://i621.photobucket.com/albums/t...9/P1000394.jpg
I don't have the backplate yet. It will probably be here Monday though. So the block is just sitting there. I also got a better shot of that board too.
http://i621.photobucket.com/albums/t...9/P1000382.jpg
That XT is a nice looking block. I really like it.
http://i621.photobucket.com/albums/t...9/P1000385.jpg
A better photo of that GTX295 in her pretty black dress for you guys. :D
http://i621.photobucket.com/albums/t...9/P1000389.jpg
Well, I will be finishing the tear down of the Cosmos 1000 this weekend. I seem to have found a place that is a bit closer to me for powdercoating. I have to talk to them on Monday.
I'll also be working on the sleeving of that Corsair PSU.
Thanks for looking in. :)
Edit: So mail just arrived and there was the backplate. Nice work Gabe. :up:
nice update and great photos. Both blocks look great man :up:
Nice update, the EK block looks cool.:up:
Thanks guys. :up:
Well, I got the case stripped down. I'll be cutting the hole tomorrow as it decided to start raining here.
Here is a quick photo of the hole that was cut in the top section of the Cosmos 1000 to mount the MCR320-QP.
http://i621.photobucket.com/albums/t...9/P1000397.jpg
Here is what is left of the case:
http://i621.photobucket.com/albums/t...9/P1000406.jpg
Ditto - looks good, mt. I like the cat!
Looking great Miller!! You have helped me out quite a bit here on the forums and always very helpful and quick to respond so it's nice to see you multi tasking with a worklog! :up: Good luck and looking forward to more updates.....
Thanks bud. The E8400 was showing its age, so decided it was time for an upgrade. I figured I have been on so much talking about your guys builds, I should show you guys what I can do. ;)
Thanks, yea that is my little buddy. He loves it outside. I had to stop putting feed in the feeder over summer as the squirrels kept getting on the balcony and stealing it. :shakes:
Yea, I was wanting to keep my HK, but the more that I look at this block, the happier I am with it. It really is a great looking block and the new mounting mechanism should be pretty much upgrade proof. You'll just need new backplates.
I just had to order up some extra sleeving from Nils the other night and the PSU is almost ready for its sleeving. Still a few more pins to pull.
:D He is an old boy. I think he is almost 10 yrs old. My mom brought him home for me from the Vet. He was one of those that got abandoned and thought the Vet was a good place to hang out. He doesn't think that anymore. ;)
He is a great cat though. Good luck on finding one of your own.
Thanks much. :up:
Thanks much. I'm looking forward to getting it up and running. I think my little buddy is looking for lunch there. ;)
MORE UPDATES!
Just to prove I haven't been slacking this weekend.
Here are a couple of mockups of the bottom Swiftech MCR220-QP with and without the Gentle Typhoon 1850s
http://i621.photobucket.com/albums/t...9/P1000414.jpg
http://i621.photobucket.com/albums/t...9/P1000415.jpg
A close up of the hole for the bottom rad.
http://i621.photobucket.com/albums/t...9/P1000420.jpg
And here are the panels getting ready for powdercoating. They still need to be cleaned, but its pretty much ready.
http://i621.photobucket.com/albums/t...9/P1000418.jpg
I hope to have powdercoated next week, and ready for reassembly next weekend. :up:
Thanks guys. :)
Excellent work their Miller, looks like you and your helper are right on track for another sweet build.
I love your photo of the trees in fall.
The one thing about OZ is, it can move from one season to another and the native landscape only goes from green to brown and back to green. It lacks the vibrant colours that you have there.
However if you keep on taking photos, like we do in our house, then you will need to buy another hard drive to store them all in.
Keep it up, it's an excellent pastime and after a while your perspective of your surrounding will change, you could say they will come into focus.
