this panel looks really good :up:
:yepp:
I agree with getting the 5870's.. also great job on the cable sleeving! looks really nice!
thanks
do you think it is possible to take the card apart to paint the red parts black without voiding the warranty?
some pictures of the bottom compartment plate
I made the opening a bit bigger so my radiator will fit
http://i846.photobucket.com/albums/a...9/DSC_0582.jpg
http://i846.photobucket.com/albums/a...9/DSC_0583.jpg
this is what I had in mind
would love to hear tips and opinions
http://i846.photobucket.com/albums/a...le2_lo_res.jpg
yea it is a very simple photo shop :rolleyes:
Edit: NM. Saw that that was a photoshop.
that is very good to hear MaByBoI thanks :up:
ps: just ordered one 5870 cant wait to see it
melle, where are you planning on mounting the fans to the rad? On the inside of the case, or on the outside under the front cover? Looking at the depth of that cutout you made in the midplate, it seems like you are going to mount them on the outside. thx
Ok, that's what I thought from looking at the depth of the cutout. Are you planning on putting the rounded front face plate piece back on afterward? If so, do you think there will be enough clearance between it and the fans? I was measuring on my x2000 here and it looks like there would only be ~10mm of clearance between them.
because I don't have any updates i will post some photo's of my super awesome cats :woot:
showing is pose
http://i846.photobucket.com/albums/a.../camera007.jpg
defending his bunker
http://i846.photobucket.com/albums/a.../camera021.jpg
keeping an eye on things (this is an old photo he now has only one eye)
http://i846.photobucket.com/albums/a.../camera009.jpg
on topic:
my video card will be delivered in then days
Hi,melle.k
Where did you ordered widow for x2000? here-> http://www.caseking.de/shop/catalog/...ck::12967.html
I've the same case. Currently i'm sleeving it and later will start with watercooling also. So, don't delay with your build :) it's interesting.
Also look here http://www.overclock.net/case-mod-wo...x2000-new.html
http://www.overclock.net/attachments...-new-side2.jpg
From my point of view additional 2 fans for radiator is not necessary b/c it's already has 3 front fans.
But probably your radiator is a bit wider then on the pic above.
Also, 5970 can by installed into that case.
hi andy2kfi
yes I ordered my case at casekings
your build looks nice I will continue mine this weekend I think
yes the 5970 will fit I didn't measures rich but it wont look good and I don't think the card is that good either
but thanks for your reply :up:
my build is progressing very slowly because I am at school from 9 in the morning to 5 midday with is very tiring because I don't have anything to do there so I go and play call off duty with my class :rofl:
on topic now:
making a cable tree right now
http://i846.photobucket.com/albums/a...9/DSC_0616.jpg
mounted an sleeved the pump and res
http://i846.photobucket.com/albums/a...9/DSC_0617.jpg
and more photo's off my 24 pin sleeved
http://i846.photobucket.com/albums/a...9/DSC_0705.jpg
http://i846.photobucket.com/albums/a...9/DSC_0704.jpg
also my video card (5870) is delayed to the 5th of January:shakes:
update
got hold off these two but they are not going in my build they are for my brother and somebody I know
http://i846.photobucket.com/albums/a...9/DSC_0713.jpg
and I mounted my sleeved cables on my motherboard witch is still on its old motherboard tray witch is from an CM stacker 830
http://i846.photobucket.com/albums/a...9/DSC_0728.jpg
:toast:
:mad:down date:mad:
I was just reading that 5000 chips from AMD where going to be available soon because off yields getting better when I got a mail that my video card is just delayed another 4 months :upset:
so I looked if there was any card available at another store and the only thing I could find is the 5870 from sapphire and that is imo the ugliest card I have ever seen. So my question is if I could pull the sticker off would it be like an normal 5870 and would that void the warranty :shrug:
I would really like to hear your toughs about this because there is really no other option I can think off besides then the plan I just explained :(
pleaseeeee help me
Get Sapphire, sure, why not.
They are all the same, just the stickers are different.
And not sure about warranty... probably wouldn't void it.
thanks very much tomorrow I will decide
just found out that my 5870 will be delivered tomorrow
:party::banana::YIPPIE::bounce::bday2::party2::ban ana2::toast:
update
I mounted the radiator and checked if the bottom and upper middle plates still fitted. had to cut some more off the bottom middle plate :rolleyes:
http://i846.photobucket.com/albums/a...9/DSC_0783.jpg
got my video card and I placed my waterblock :yepp:
http://i846.photobucket.com/albums/a...9/DSC_0796.jpg
http://i846.photobucket.com/albums/a...9/DSC_0800.jpg
and I got a new measuring tool so I don't ever measure wrong again :D
http://i846.photobucket.com/albums/a...9/DSC_0806.jpg
and I got meself a sleeving tool :clap:
http://i846.photobucket.com/albums/a...9/DSC_0808.jpg
http://i846.photobucket.com/albums/a...9/DSC_0811.jpg
I am trying to improve my photo skills
