50W load wouldnt need any PCIe connector at all would it?
I just want to show that the 5750 was not tested under the same platform. Check the '06 scores and the system details in the screenshots.
5750.... 4GB ram, Windows 7, E8400 3Ghz.
http://www.mymypc.com/images/vga/mymypc-hd5750-5.jpg
GTS 250 ... 3 GB ram, windows vista, E8400 3Ghz.
http://www.mymypc.com/images/vga/mymypc-hd5750-11.jpg\
For HD 4770 and 4850 it;s the same setup, 3GB ram, vista, E8400 3 Ghz.
About the results, it outperforms all of them and since it's not the 5770, i think it does well at outperforming all the previous midrange cards, probably trading blows with 4870, though that remains to be seen with proper testing/game results.
The 5770 should be a very interesting card, over 4890/under GTX285, for just 200.
I dont want it for the gaming. I want it for an HTPC. I need a low power card that can do Blu Ray 8.1 audio over HDMI. Simple FTW.
thanks for joining us. not to throw hate at all, but 3dmark06 is horrible at comparing GPUs being so cpu limited, which i think is taking away from how good this card really is.
the review/preview originally linked thought the 5770 would take over for the 4890, which i strongly feel is possible given the difference in sharders and speed. but its hard to believe that with current information showing these cards being quite low. i hope the whole 5000 line get 20% stronger with new cat drivers by end of the year.
Any idea if this thing is faster than a 4890?
Are we sure the specs quoted in the first page really what the card has? If its true something has to be wrong.
This will be a killer HTPC card...
Lots of misinfo...
The card in the test/bench was a 5750.
5750- 800SPs, 40TMUs, 16ROPs, 128bit, 1150mhz GDDR5 and 700mhz core.
Which it should be performing a bit better than a 4850.
The 5770 is supposedly still a Juniper w/ 1120SPs, 56TMUs and 128bit. I haven't heard any confirmation on clocks but I would guess ~800mhz core and 1200-1250mhz GDDR5.
I'm sure the card performs great, but just had to post here and express my disgust at how ugly that cooler is :p:
Su
So 5770 is a Juniper but 5750 isn't? What a mess...
And 5770 is going to be the only Juniper card then? :confused:
Or am I getting something wrong? (Probably since it's all strange this way... is 5750 a crippled Juniper and then everything fits perfectly in my head? Sorry, I am absolutely thick now...)
This depends alot on the game, settings and the situation in game. We don't really know how much the 128-bit bus will bottleneck the card, and under which settings.
Using AF will be expensive though, IF the bandwidth is a bottleneck. So there could be some real gains by using 4x or 8x over 16x AF in terms of performance. Sacrificing the IQ of course.
I believe that HD58xx cards are based on Cypress while HD57xx are Juniper. 181mm˛ and 330 mm˛ difference seems quite big for 1120 -> 1600 SPs. ;)
