wow 4.7ghz gulftown air cooled - my kind of cooling/setup hehe
Andre what's the idle/peak load power draw measure as for such a setup ??
There is no increase from TriCF to QuadCF of HD5870s, at least for 3D06. Same goes for Vantage, 4x5870s would be able to destroy 4xGTX275 (2xGTX295), and they score lower.
http://lab501.ro/forum/attachment.ph...6&d=1254151331
The +1500 increase in CPU score is because of the 6 cores/12 threads. But in GPU score, 3x5870s at stock get better results than 4x5870s stock.
Looks really good, and VERY nice frequencies - I keep my fingers crossed that we wont have another episode of "waaa, why cant I upload my scores on HWB & FutureMark", stay put untill official release before results can be used for competition purpose :-)
It seems to be a very good CPU the Gulftown, likes cold, scales well, performs superb, I just hope that the benchmarks wont start scaling well for graphics...
7x HD5870X2, wuuuh, that would be sooooo great buying, would really benefit the sport, allowing everyone to have a chance for participating...
I do NOT like the eVga "More more more is better" trend, its simply ruining the fun in benching... :down:
Or wait, lets all go out and buy computers for 5000 USD++ !!!! ROCK ON !!! :rolleyes:
Yes run 3 cards.
Four cards are clogging up the lanes.
Gulftown is looking very very good isnt it :)
show us 6.1GHz 06 :D
the SM2.0 and SM3.0 scores of 3D06 scale only with one core
only CPU-score is multithreaded. So unless you do some 5+Ghz runs you're completly bound by low-freq cpu.
regards
:slobber:
Thx for sharing!
Who want gulftown? :D
Damn that's great scores ^_^ and i would also like a Gulftown :)
I have never seen a chip get so much profit from a 13nm shrinkage :)
I test it on air finally and oc 5870s a little bit . LN2 results soon.
Vantage Entry
http://www.iamxtreme.net/andre/E762-Test/15.jpg
Vantage Performance
http://www.iamxtreme.net/andre/E762-Test/12.jpg
Vantage High
http://www.iamxtreme.net/andre/E762-Test/14.jpg
Vantage Extreme
http://www.iamxtreme.net/andre/E762-Test/13.jpg
X27563!!! :clap:
:shocked:
What are you using to increase the GPU Cores Voltage above 1.15v.
RivaTuner with v1165 addin does not work.
My Asus EAH5870 does not maintain the volts set with Smart Doctor above 1.15v.
My Asus EAH5870 can only do 980/1300 max until I find a way to pump in some more volts.
Will try that MSI tool tomorrow though.
