I agree. And it will be easier to get to the barbs etc.
Nice, btw. Been sub'd since the first page haha.
Looks really cool with the white/black enermax fans! Keep up the good work ^_^
Sub'd!
Love your attention to detail so far mate.
Excellent work!
Looking forward to more updates :)
Thanks :) Glad you like it ! (I like it too :p)
Am currently trying to remove the 4pin PSU and PCI-E cable to sleeve them... but 1hr try and 0 done :mad:
Those Corsair PSU are a pain in the back side... I've tried stable, Molex pin remover and another pin remover... This is getting on my nerve now :shakes:
Wow looking great so far man. I am saving up to get this case cant wait I just love everything about it.
I was thinking, what about a single 120.1 rad at the bottom instead ? opinion ?
DO you mean a single 120.1 instead of the swiftech 240mm infront of the harddrive cages?
If you do so, where will you keep your pump/pumps?
Anyway, if you wanted my opinion on it: Keep the 240 rad instead of that 120mm.. Looks nicer with bigger rads (again.. my opinion), and it cools better.
Yes, I mean single fan rad at the bottom of the case instead of the MCR220 in front the HD cage. The pump/rez will be fitted on the MB tray.
Am sure i will have enough room for the MCR220 rad and the GTX285. I will see how it look. But from other project using this method I have seen, am no so much of a fan on the way the barb will be facing... we will see I guess
I got some stuff this morning in the mail :D
http://farm4.static.flickr.com/3073/...e1200b2b_o.jpg
the i7 920. Stepping 3844A848. I hope they are good
http://farm3.static.flickr.com/2477/...50707883_o.jpg
Corsair Dominator 3x2gb 1600mhz CS8
http://farm4.static.flickr.com/3492/...d5fc54c2_o.jpg
nice stuff
http://farm3.static.flickr.com/2444/...652c4716_o.jpg
Seagate 7200.12 1To
http://farm4.static.flickr.com/3439/...0e669826_o.jpg
ouhh ! this took time to get in stock (at a good price !)
http://farm4.static.flickr.com/3419/...4d6ebeb3_o.jpg
but money well spent :D
http://farm3.static.flickr.com/2535/...43a2a2ea_o.jpg
The video card
http://farm3.static.flickr.com/2618/...b48b18b7_o.jpg
And the RIIE
http://farm3.static.flickr.com/2653/...ac9405a0_o.jpg
That all (and not too bad already lol)
Am still waiting for an order from PPCS, but it take time to get it over here in Europe. Still waiting on the waterblock for the RIIE and the GTX.
its moving, slowly, but its moving :)
The i7-920 chip you got is C0/C1 rev. Its not bad, but gonna need to use higher voltages to get a stable OC. Awesome parts though... I got the same mobo, love it.
well, i have no clue how i can get a D0 here in france.... how do i see that its a D0 ?
The spec would SLBEJ for D0.
Its not horrible that you got a C0 chip, just that it might not OC as high with the same volts that a D0 can. You should be able to get relativly the same results... just with higher volts and slightly higher temps but if you want to OC the chip to around 4ghz, you should be fine.
Ok, thanks, i see if if can find this thing in the local shop. I want to make a nice Oc tho, 4ghz minimum
with the price of the whole build, i want the best i can get. So am going to ry to find a D0 (if you know a US shop that ship in europe with D0 in stock :))
Little update.
Still waiting for a couple order so i can move on. been busy this week, so no much time to work on this. (only have time the weekend mostly)
i got some sleeving done.
The 3 SATA cable am going to use (all Straight/90°)
http://farm4.static.flickr.com/3511/...4e863d2a_o.jpg
Nils provided me some Black sleeve, so I tried them on the temp sensor with the RIIE. (did not have good quality heatshrink) but it's look good.
http://farm4.static.flickr.com/3433/...453e7743_o.jpg
And the work done on the PSU so fare.
http://farm4.static.flickr.com/3441/...34cae907_o.jpg
Am not sure what to do with the 2 extra pin on the PCI-E (for the 8pin). I Think i'll just sleeve them and hide them somehow.
Am waiting on the 1/2 heatshrink so can make the whole thing at the base of case look better.
More news, soon, Thanks for watching :)
Looking great, Ced-G60.
About the extra 2-pins for the PCI-E cable, you can always cut them off (and then just re-solder them back on if you ever have the need for them), but you can also hide them as long as you leave them long enough.
Thanks for the tip, i just cut them and hide them i guess.
i got some more stuff this morning.
Koolance full RIIE kit.
http://farm4.static.flickr.com/3551/...f5b9c842_o.jpg
looking nice
http://farm3.static.flickr.com/2462/...d6663547_o.jpg
Some more gear. Bitspower G1/4 fitting. with some 3/8ID 5/8OD Primochill
http://farm3.static.flickr.com/2531/...71af6de4_o.jpg
That is all, I did some more work of the PSU, but am short of sleeving again (damn i keep not ordering enough :x)
That koolance block is just beautiful :O
Gotta love the koolance blocks. If i was water cooling my mobo, those would be the block id get.
You shoulda just ordered the Psychopack from MM website lol... yes its extra money... but you would have way more than enough ud need in case you end up making mistakes or don't like the way it looks.
Yes, but they don't have it in white...
Beside, now am Nils best customer in France :rofl:
I got the paycheck this morning :D so I can order the rest of the missing parts. I want to order the GPU block. I need opinion.
EK Rev1 Nickel with Pexi top
Or
Koolance full nickel top ? (does it fit on Rev GTX285 ???)
Yes, i think i'll stick to my original though with the Ek version.
Small news.
Removal of the original RIIE blocks
http://farm3.static.flickr.com/2562/...f4f0f5dd_o.jpg
Here we have some great quality control from ASUS.... :down:
http://farm4.static.flickr.com/3483/...15ed7b25_o.jpg
The Koolance kit install. missing one the mofset block. PPCS did not have the plate for it. Am ording it from highflow this week.
http://farm4.static.flickr.com/3496/...993dd9c0_o.jpg
Ill have some better quality picture once its done :)
