What about 2x1gb stick that can do 6-6-6-1600+ can you get that? then i would be int.
Thats wy i am asking i am looking for a set of mem that can do 6-6-6-1600mhz+ 24/7 but only 2x1gb
Find something with micron GTR/GTS....most likely going to need 1.9v for 24/7 6-6-6 1600 which is why i don't reccomend them......I have a feeling if and when we get an exclusive ddr III IMC things are going to be "different"
I am personally leaning towards the lower volt stuff now.
That was interesting..
I want play with Gigabyte very soon thats why I cannot afford 2x2 at the moment. :D It will be interesting contest vs ddr2 brothers.
I see you suggested Ocz Reaper. Heatsinks look cool. Too bad my Ninja 2 is very Fat compared with slim True :) So I go with Crucials. I suppose there is chance for GTR/GTS too?. Gigabyte would love it, right? :D
found some links from UK shop for quite lower prices compared to "official" prices directly from Crucial EU.
Ballistix 1600
Ballistix 1333
I dont know which to pick :p
Well, unfortunately crucial is a crap shoot for micron, Only way I have found to be guranteed is by buying the 2000 bin.....Msimax and myself have found them to be short lived as well......I think his degraded and mine did to undervolted.......
found OCZ Reaper what Chew suggested but from Europe .. Guess which shop? Amazon.de :D 52 euros
OCZ Reaper Enhanced Bandwidth
Found also that Trident 6gb (2x3gb) which costs 165 euros. It is 1600 version, cas6.
Trident 6gb
EDIT: last link is changed.
I couldnt resist and ordered OCZ reaper :P Furthest two memory slots will get places. Not other pair at closest. We'll see, I will check if 2x60mm fans can work on ;p
what about G.Skill Ripjaws DDR3-2000 2 x 2gb 9-9-9-27 kit?
i saw another thread over in the xtreme bandwidth section.... was wondering how these faired with the phenom II 955-965
http://www.newegg.com/Product/Produc...82E16820231281
Running my previous kit 2x2GB without any trouble.
I was afraid that 4x2GB would not run.
But is runs fine @7-7-7-20@1,7V.
I would recommend this kit also
Yes, it's in my sig. And yes its stable with vista 64bit
I didn't test it with any memory bench but is runs at the recommend speed
i have the same kit and i can run it at that speed but it is far from stable though
I have 4x2gb of the Mushkin 7-7-7-20 memory. Running at 1600mhz 2t timing all 4 dimms :). I haven't pushed it higher yet b/c I'm waiting to remount everything in my watercooling setup.
one vote for geil ddr3 2133 cl9 (4GB kit), pretty decent IMO... :)
http://img2.pict.com/5c/e9/8d/167395...0407772433.png
I have OCZ Reaper CL7 2x2Gb 1600Mhz
Uses high voltage(1.9v) but so far so good
But i can down a little
CL7 @ 1600MHz 7-7-7-15 1T (1.75V)
http://img35.imageshack.us/img35/1339/cl7spi.th.jpg
CL7 @ 1800MHz 7-7-7-15 1T ( 1.95V)
http://img182.imageshack.us/img182/7...3900mhz.th.jpg
CL6 @ 1600MHz 6-6-6-15 1T (2.1V+-)
http://img98.imageshack.us/img98/883/cl6e.th.jpg
And a Try CL5 1600, but no boot.
But 1348Mhz can
CL5 @ 1348 5-5-5-15 1T (2.1v)
http://img255.imageshack.us/img255/1925/cl5spi.th.jpg
I use 24/7
CL7 @ 1600 7-7-7-15 1T ( 1.75v).
sorry my English
after some testing my kit failed in some tests.
But when reading this article:
http://www.lostcircuits.com/mambo//i...1&limitstart=1
and setting the ns/sb to 2600 and adding volts aswell the kit runs stable.
Pi run @3,8ghz@2600@2600 32M stable.
Thats enough for me.
well i got this mobo: BIOSTAR TA790GX A3+ 5.x what ddr3 memory for this board ? i think about ripjaws CL9 F3 or CL7
?? they will work fine ?
