dave u always seem to impress me in your innovations on mounting things.
Great work bro!
Great work bro!
Thanks NaeKuh
That's my nich to figure out how to make your builds easier!
Find a need, fill a need, that's my moto (if I had one)
Very cool!
I think These will also be a convenient way to mount some fans to the front of my Lian Li. Looking forward to these!:D
armeniandave It's gonna be available in Perfomance PC's ?
This is exactly what I need!
So for now please help me to find this in PPcs, no ideas in which section it should be :confused:
this is going to delay my build another month.
fml.
Why? Dave's bracket is not a totally new thing functionally speaking, it's just 3000x nicer looking than what's already available, and can accommodate 140mm rads.
EDIT: added totally to ward off the drama engine.
EDIT2: and slightly more expensive.
because i was unaware of the lian li product.
many thanks! i'll definatly look into those.
zeropluszero there is always the Lian Li brackets.
They do work there just a bit more industrial looking than mine are. Nothing wrong with it, it's just a different style.
Good to see the Aussies are being represented here on the forums! This truly is a global community! :up:
as i said dave, i was unaware of the lian li ones.
i'm thinking i'll hold out and get yours, because quite frankly, you deserve it. i have a pump stand, and it's fantastic. i need a second one anyway as well.
there's a select few of us here on XS, there's some info here that you just cant find on OCAU.
now just get a store in australia to sell your products ie. PCCG or GAMmods and i'll be set :) *hint hint*
I just thought of a good use for these and your z-brackets. Mount your radiator with these and then add to Z brackets to the radiator on the inside portion of the case and you now have a place to mount an EK Multioption Res.
I would love to pick up a set of these. I have the Lain Li one, but don't really like it very much.
c'mon dave! faster! haha
Just wanted to give everyone an update and tell you all brackets are going out to the shops first thing Friday morning.
Thanks for your patience and I hope to see these put to good use!!
I am interested in your ideas and would like to subscribe to your newsletter...
http://img524.imageshack.us/img524/4089/dscn1510sy1.jpg
these radiator brackets are amazing. thanks heaps ArmenianDave!
I'm really stoked that you like them!
Any chance that you could take a pic or two?
Thanks!
Dave, I have one question, what's the thickness of metal that is used for this brackets? I am building system with thermochill PA140.3 and I am going to install it into the drive bays of Lian Li P80 so there is only 2mm or less on each side between rad and bay panels.
I am teasing my mind whether your bracket will work or not :D If there is any chance that it works in my particular case I'll pick them with my next order at PPCs just to check how it goes.
Well 2mm is .078 inches and the brackets are .075 thick!
It will be close but definetly doable. There is a little flex
in the cages also.
i'm doing some dremelling of the case today, so i may have a chance to later.
nothings mounted properly yet, just did some test fitting last night and its exactly where i wanted it.
on a side note, perhaps the only thing missing from this package is slightly larger screws (in the head and nut, not the threading) and perhaps some short screws for attatching the radiator to the brackets on a future revision? i found some screws that will be suitable for my Feser and the screws provided are holding fine, just looks a little small to me.
