It's a matter of density...
Originally Posted by
art_h
This is a very interesting project.
I hope I am not too annoying with too many questions.
What is the Significance of 56K warning in the title?
Someone suggested to me that there is a solder suitable for SS.
Mfg: Harris Brand Name: Stay Silver 15 and Stay Silver Flux. Does anyone have any experience with this?
I guess brazing is preferred to solder?
Can anyone comment on the concerns relating to the selection of a brazed plate HX?
The main concern may be that you have the same or better heat transfer.
Can you have too much heat transfer?
The brazed plate HX seems to be much smaller in volume, is this a concern?
The brazed plate is an extension of the fin and plate design. The major advantage here is it's surface area. The brazed plate design simply transfers an enormous amount of heat in a very small package. The only thing that could be better, would be one with more plates. You won't get any better than this design. It's used in many industrial applications by corporations for which money is NOT a constraint. If there was better, they'd be using it.
Shingoshi
Naja002. Take a look at this...
I think you might find it interesting:
http://www.hardforum.com/showpost.ph...2&postcount=92
Also, have you considered using the principles of an autocascade in the implementation of this system? It just seems like an interesting way to maximize the efficiencies of all your work.
Still loving what you do!
Shingoshi
Naja002, have you seen this???
I think someone posted this in one of my threads for me to see. I think you should look at this. This is one intense piece of information.
http://www.xtremesystems.org/forums/...d.php?t=144007
Cool deep, and chill out! :rofl:
Shingoshi
Yeah! It's above my payscale too!!
Naja002
I don't currently have the knowledge or experience to deal with cascades or autocascades, Shingoshi. They are a lot more technical then what I am currently doing. It's not as simple as adding another compressor or mixing gases. :up:
I'm just looking around to see how much trouble I can really get myself into. As though I don't have enough to worry about! :ROTF:
Shingoshi
This has always sparked my attention...
I love Wikipedia. It makes me feel like the kid I was sitting in the library pouring through research materials. Yeah, I'd rather be there than out playing.
But this is what makes me excited now:
http://en.wikipedia.org/wiki/Absorption_refrigerator
http://en.wikipedia.org/wiki/Einstein_refrigerator
I've been looking for ways to adapt this into powered systems, to lower the expense of the power used. It's just an interesting alternative that I continue to explore.
And then of course, there are Vortex tubes, and wondering how they could be added into a refrigerant system. Somewhere in the proximity of the evaporator, and dumping the heat off to the condenser.
Shingoshi
Sorry about apparently hijacking your thread...
I was asking if things could be introduced into the current project, while it's still not completed, to increase the efficiencies here. But you're right. Sorry.
Shingoshi
It's better not to get wet...
Since I believe condensation is better removed from any cooling consideration, I think this thread applies to anyone who wants to maximize the lowest temperatures they can achieve.
http://www.xtremesystems.org/forums/...t=condensation
This will hopefully help anyone interested in having the absolute best cooling without any limitations. At least it will be a starting point for examination.
Shingoshi
I hope you still have more hair that I do...
Because I don't have much left. And by now, if I were you, it would all be gone!! I really hope you can get this thing to work. I empathize fully!
Shingoshi
