I've bent a few Nylon tubes with boiling water and springs before, but I think I like your method a little bit better. :up:
Single Radiator vs Dual Radiator. This new case kicks some serious ass.
EVGA 780i - P08
Q6600 G0 L747A [ 400x9:3.60Ghz @ 1.45v ]
xFx GTX260 216 Black Edition [ GPU:740Mhz Shader:1515 Ram:1215Mhz ]
6 GB OCZ Reaper DDR2-800 4-4-4-12 [ 990Mhz ]
750watt Silverstone Modular Strider
2x HDD [ 1 TB ]
http://i30.tinypic.com/2z7e4g8.gif
Single MCR-320 Loop.
T-Line > D5-Vario > MCR-320 > Apogee GT > MCW-60r2 > T-Line
IDLE
http://i28.tinypic.com/1zmjec2.jpg
LOAD
http://i26.tinypic.com/mrwe2x.jpg
Dual MCR-320 Loop.
EK-150 > Pump > MCR-320 #1 > MCR-320 #2 > MCR-60r2 > EK-780i NB > Apogee GT > EK-150
IDLE
http://www.picstation.net/image-A3F6_4A8CBC2B.jpg
LOAD
http://www.picstation.net/image-1649_4A8CBC2B.jpg
Testing method: absolutely none... I just happened to have a few "before" screen shots... and a few "after" screen shots. I am however using the same thermal paste, same speed fans, same size tubing. I did however add a reservoir and add a North bridge block.
I was surfing around XS and showed my wife your project log. She said to post that she likes the wood design and contrast of the front pieces.
this OfT - I was thinking about making my own canoe the other day...
thx for the compliment =D
Go for it, a canoe will be a fun build. I've build a wooden sailboat. It takes some time and effort though.
Currently the case is in my dorm room, not 100% done yet, need some more cable sleeving and some faster fans. These Yates aren't moving enough air.
