Is it only for trial runs or XP is now #1 choice instead of 2k3?
Congrats :)
Very good example (as always from TeamJapan) how WR setup and posts are made, respect :up:
i was expecting this :D
Again, thanks all for your hearty words:)
@massman
Thanks for the static data however, the real OC world is so dynamic to consider many variables especially under extreme cooling as you know:D
@kiwi
kyosen made extensive tests and the XPSP3 results were slightly faster than those of 2K3SP2; believe someone from Team Italy showed us the same in the past.
:shocked:
fredyama is back in the action. Cogratulation man, you're the 32M king :worship:
Grats guys, really impressive! :D
Woah at uncore frequency!!! :shocked:
Congratulation's Fredyama san. :up:
cheeeaaaattt!!!! fake!!! ^^
congrats fredyama-sensei and duck-san! :toast:
too bad i couldnt meet up with you guys in tookyo in april...
noce to C U back , congraz for WR ! :up:
Nice one my friend... :D
Let me tweak this "flat run" and I'll be back... :D
P.S. This was done at LOW CPU frequency... ;)
P.S. 2 This was done with only 1.47VCore....Guess were it benches with 1.56VCore... :D
P.S. 3 It was done on a Foxconn BloodRage - STILL waiting for a mobo IF "someone" hears.... :(
In the end I will be "forced" to bench with the Foxconn I think... :(
Helloooooo!..... :D
http://www.hwbox.gr/attachment.php?a...2&d=1245001986
Hehe....Hipro the blood is a fast board
gandalfone is right, the Bloodrage is one of the fastest X58 boards out there.
Hipro, get yourself a good 6GB DDR3 Kit and, bump that uncore two noches and you got yourself a SPi 32M WR baby :D
Nice chip BTW.
Wonderful 32M, but why did you use such low memory clocks ?
no need for high mem clocks if you push uncore frequency (proof) - fredyama had uncore >5000mhz hehe
Unless I'm reading wrong, all you "proved" is that uncore helps, not that memory does not help.
yeah that's what i'm getting at... :)
give the guy a chance...he literally just started benching with the setup lol
there is definitely room for improvement but he knows it anyways
i'm sure that we will be asking DAMN HOW DID YOU DO THAT very soon
:D
As Gautam said, it doesn't proove that 1100Mhz+ won't help...
Maybe, but i'm asking this because 90% of the 32M i saw these days are done with less than 1000Mhz mem clocks...It's amazing because all your sticks can easily hit 1050 C7.
I'm sure it will be better with higher clocks, and even if it doesn't help so much, it will help (every ms is goo to take).
Then you haven't tested the rams at 840MHz Cas 6 - 6 - 5 - 18 - 1T and Uncore at 5040MHz.... ;)
The lower the ram frequency is with tight timmings, the lower latencies in the internal mem controler are... :)
Just wait.... ;)
I understand my friend....Don't worry... :)
Wonderful work Freddy and Duck :up:
Thanks so much all:)
@hipro5
Hello my great friend George.
I still vividly remeber the OC bench session with the world greatest OCers at your lab:D
You certainly have an awesome CPU and look forward to your far out results soon;)
@saaya
:confused::(:rofl:
What a pity we missed you here in April:( Hope we can get together in Akiba next time:toast:
@k|ngp|n
Very much regret to miss the best opprtunity to bench with your F1 duck-edition. We will bench together again & send you some pictures soon.
@gandalfone
Thanks for your confirmation:up:
@Pt1t
Yep, definitely many weird things happen under extreme cooling:D
About memory settings & modPI, perhaps the below database may be of your interest.
No need to post your comments on these results, please:D
8M Ranking at tanuki, 45GP-i7 at tanuki & 32M Ranking at OMEGA
:toast:
OMG i found one too :D
http://www.pt1t.eu/public/X58/975/45B/975xe_45B.jpg
