3.8ghz 0921 apmw GA-MA790FXT-UD5P F3K
http://premium1.uploadit.org/bobbyboyuk//3800.jpg
Yay, finally got a couple of different steppings to try..
2 x 0922APMW's, I'll be testing them Monday/Tuesday :up:
C-BuZz
0921 APBW - Davidw8818 - GA-MA790X-UD4P - F5 - Success - Link - http://valid.canardpc.com/show_oc.php?id=589023
Nice work, now crank it up & lets see some 3d action :up:
Thanks, luck is exactly what I need :rofl: Hopefully these newer steppings have more potential.
Do we have anyone else with 0920 results? Or am I the only one :shocked:
C-BuZz
0922apmw - Lucky_n00b - ASRock M3A790GXH/128 - P1.10 - Success
Hi guys,
I've just bought one, it's 0922 APMW, the same stepping as lamby_splendid have (well, it's not like I have much choice, in Indonesia most of the X2 550's are 0922 APMW stepping )
- X2 550 0922 APMW
- ASRock M3A790GXH/128, BIOS P1.10
- G.Skill PC12800CL7-2GBHZ
- GELID Silent Spirit HSF
BIOS all Default, just change the ACC to AUTO, and set the DDR3 freq n timing manually, and...voila! 4 core unlocks , lucky me ;)
and a little overclocking from AMD Overdrive, just change the cpu multiplier to 17x, all voltage are still default..
Unlocked 4 Core, 3.4Ghz, Linpack 32-bit 10 min START
http://i419.photobucket.com/albums/p...packStarts.jpg
Unlocked 4 Core, 3.4Ghz, Linpack 32-bit 10 min PASSED
http://i419.photobucket.com/albums/p...ackFinishs.jpg
nice run lucky_noob..!
lucky you have there alva.. :up:
wonder how much the board cost?
it's interesting that you use that board
Hi mate,
The board costs roughly 130 USD, pretty much the cheapest AM3 board available in Jakarta at the moment, and since I'm REALLY low on cash, I don't have much of a choice..
* well, I probably should just buy a cheap AM2+ board, but I feel like getting an AM3 one :p: *
0919EPMW - Partizan - Asus M4A78T-E - 1402 - SUCCESS
http://www.shrani.si/t/c/nT/4WKbwwjM/4cores.jpg
Didn't have time to play with OC yet :)
http://img241.imageshack.us/img241/5123/550.jpg
0918BPMW
Biostar TA790GX A2+ Mobo + BIOS Dated 01/13/09
3.7GHz prime95 blend stable.
wew nice im getting my 550 tomorrow wish me luck :D
1st one of my 2 x 0922's
0922APMW - C-BuZz - MA790FXT UD5P - F7 - Success - Link
Looking good so far :up:
http://i42.tinypic.com/16izmec.gif
C-BuZz
2nd processor installed 0922 @ Quad Linpack stable 3.825Ghz 1.5v bios (haven't tried lower).
0922APMW - C-BuZz - MA790FXT UD5P - F5 - Success - Link
http://i39.tinypic.com/drce9e.gif
http://i43.tinypic.com/23lmqm9.gif
C-BuZz
nice one c-buzz, bet your dead happy :-))
I will say if you have a steppiong Above 0921...it more than a 50% chance you will have a great X4.
Best budget chip ive ever used.
I know, I called and told them they sent me th wrong chip and offered to pay the difference. The lady said "keep it and we will send you a promo code $10 off your next purchase for your inconvenience". I must say thoguh, the 955 does clock higher with less volts when going for stable.
Got a 550BE 0922APMW today to go with my GA MA790X-UD4P.Waiting for my new memory and HDD which are coming Wednesday.
How high do you think I can push this 550 with a lapped Arctic Cooling Freezer 64 Pro?
I had my 3600 Brisbane at 3.1Ghz full load 47c
Well I had my 550BE 0919EPMW at 3.8GHz (200x19) at 1.4V, the load temps when running prime were around 45'C. That was using the same HSF as yours (lapped also) but my case has 4 120mm 60CFM fans which shift a fair bit of air.
What I found with my chip is:
200x18 @1.3V (stock volts) = ok.
200x18.5 @ 1.35V = ok.
200x19 @1.4V = ok.
So I needed 0.5V more per 100MHz step after 3.6GHz. (This was with all other voltages at stock, NB, CPU-NB, etc)
Good luck, hope your CPU unlocks to 4 cores and is a good clocker :up:
