UPDATE THE X4_550Beast lives...time to play UD4P..goodness
First off i set Defaults and unloaded the 720 andInstalled 550BE.
1st BOOT In Hybrid Mode,, F5A Bios UNLOCKED .
Next :
Noticed is Vcore is 1.35v Default.
Then:
NBvid is @ 1.1vid Default... This is lower than my 720 @1.2vid
Now :
Im getting and Idea where the Temps are and will slowly bump up the Volts to see how the Heat rises.
Interesting :
It may be a 955 variant. Its temps are 26c Idle Bios @ 3.1ghz X4cores and 1.34volts .
The 720 was 28c Idles@ stock 2.8ghz X4cores 1.3volts.
It could be the default NBvid too. Only way ill know is to raise it up some:yepp:
Last serial 90020........Step is 0921 APAW:D
http://i168.photobucket.com/albums/u...4P_F5Abios.jpg
Will post clocks later,, Im seeing what volts this thing likes and if the NB goes higher than the 720 @ stock NBvid volts.
