I was just thinking that I have seen or experienced 8 hours of stability testing, but cant run 24/7 for an extended period of time.
If a system can run for at least a month straight 24/7 then I would consider it stable. I havent run stability tests in a long time, but recall in the past running stability tests for 8 hrs easy, but sometimes wouldnt run for a full 24 hours.
I know its a pain to run tests for a day or more. and in your case if it runs fine 24/7 with no issues then I would say its stable.
I myself couldnt come up with a better solution, so I guess 8 hours works, :ROTF:
I just know there are a lot of bench junkies that could probably prime for 8 hours but doesnt neccessarily make the system fully stable. I thik this thread should be to help others see what they should be able to expect for Truly stable machines; which I hope and feel that is how its turning out, which is great :up:
