Review is up , see sig :) Pretty impressed as it is a nice bang for the buck CPU
thx for the nice comment
Well I'm pretty sure the one we got would do 5.3-5.4 for benching purposes, we put 1.8Vcore in the bios and cooled it under the cascade and let it complete all the runs like that. If we pushed more vcore we could have gotten CPU-Z higher too for sure... but it was just quick fun that afternoon...
plz, can someone post his bios settings with E6300 to hit 4 GHZ ?
Which motherboard ? On the Giga EP45 UD3LR it was dead easy
on DFi JR P45... i tried different FSB strap and i think the only one wish rocks i 266. I even can't boot windows with 333 strap
I think you need to set TRD setting yourself as it's too tight, try loosening it to 9 eg. Also the Nb GTL value has to be correctly set. If this mobo is anything like the early biosses of the DK, then it's best to create a Mem86 bootcd, it's so easy to corrupt ya windows install when trying to look for Max OC. Which Bios are you currently running ?
My friend tell me this little monster can reach FSB 500+
here is my friend result
http://forums.overclockzone.com/foru...0&d=1249116477
Drop multi to eg 8 or so and set 1.35Vcore.... leave CPU GTL's alone, set NB GTL to 0.64ish region, try first 333FSB and work ya way up
Hey guys, Got me PCD E6300 100% Linx stable at 4.2Ghz with 1.64Vcore 24/7, Is that a bad clock compared to most? :)
that vcore is really high for 24/7. are you on air? how did you manage to use vcore that high and didn't run into the thermal limit using linx?
The clock is nice, but how do you achieve it ? via 400FSB ? if I was you and if ya mobo can handle it go for 8 x 500, will provide you very good bandwith and really 1.62 volts is far too high for 24/7 even under water.My sample did 4Ghz 1.42vcore... 4.5 at 1.55Vcore
hi guys let googling with word "E6500K" you may see new 45nm star!!! (unlock multi)
It's at 1.64 Vcore for a reason :)
See my thread :)
http://www.overclock.net/intel-cpus/...ing-final.html
And was your chip 30 runs Linx stable testing all available memory?
None of my cpu's are linX stable as I don't even test that, they are folding ,game and bech stable.... under the cascade it was stable at 5.2 no sweat at 1.8vcore :p
I absolutely don't care about IBT... as it has been already been proven a zillion times that it's not THE test. It's overhyped as it produces excessive heat and people think it's a better test then...
and why do you want to prove some myth that has been busted before, if you have a good cpu it will last , if you got a dud one it might degrade in weeks at stock volts lol... mostly you will degrade ya mobo sooner than a well cooled cpu...
For ya little comerades on your forum search for Benchzowners thread on the vcore fsb term thingy. Bill has put several real £OC'ed Wolfdales at +1.5vcore, 1.5vtt;PLL 1.7 for weeks... on air !! none has failed... he lost one mobo in the process as his test was 24/7... your about at least a year too late on this matter....have fun, with it but it's a waste of cycles... even if yours should fail you still haven't proven anything...
Bought one yesterday to change out my 6600ES and it is a nice cpu for 65€! Oc is average but much better as with my previous cpu! ;)
http://www.abload.de/thumb/e6300_primezlxu.jpg
http://www.abload.de/img/e63001ggzm.jpg
Will change the board soon, bcs. have a lot of fsb problems with the old P5B. P5Q-E is on the way!
Hope you can stabilise 8 x 500FSB mate and enjoy the extra ram bandwith over the P5B Dlx... I really liked this CPU a lot...
It's getting better now! :)
http://www.abload.de/thumb/zwischenablage01f027.jpg
Hello and sorry for my bad english
my E6300 is OCCT stable 1.352V 470MHz x 8.5, it run also 4.2GHz but with about 1.5V and more T°
so 4GHz its good for me :)
http://www.monsterup.com/image.php?u...0444703624.png ambiant T° : 26°C
So is it dead yet as you claim to have a no post a while ago ? Didn't know a degraded CPU wouldn't allow a mobo not to post,unless it must be seriously damaged, surely as you have more than ample volts to fire her up...If the cpu is down the drain and to back up ya story, you wil need to test another one and for verification send that dead/degraded one to me, I'll test it and try to RMA it for ya...
I would want to post more but I'll get an admin up my a s s;l For starters I haven't seen any daily results, tests,... you can write whatever you want in fact. How on earth can you prove to me you are telling the truth ? Blind faith I have absolutely none, looking at the way this test is conducted (you change variables all the time , let her run on AUTO for a while, then change this, then that,... :shakes: have you even measured the Vcore voltage with a Vdimm ? and so on ...
yep better to run a CPU at a sweetspot and keep temps/voltages (electricity bill) under control , no use for them extra 200mhz
That is the max for aircooling now. But my 24/7 setting is 4100MHz 1.432V load.
http://www.abload.de/img/primef2bd.jpg
