remember just keep it cold
Yup, I saw the vcore was a bit low. I'm going to give the 955 I'm running another go in about a week, but this time on a DDR3 board, hopefully the Crosshair III. Just need to get my M4A79 Deluxe RMA'ed.....
Nice job Chew*. I've been too busy (or lazy) recently and MSI 790FX-GD70 killing my best chip :( But.. sooner or later :P
You can probably smoke that with your worst chip :p: I want to see 30 K plus :up:
The MSI is very sensitive to any moisture near PWM it seems. Might want to give it another shot with a dud first.
Either that or the latest bios got it to work for us.
Time will tell.
I think I am late for the party.....
http://img37.imageshack.us/img37/100...2909ppuoff.jpg
Hey Sampsa did you get a voltage tuner to work? I tried the evga one my friend uses but I get lock ups. Thx.
Ok update....
http://img29.imageshack.us/img29/415...09physxoff.jpg
Just for reference Vantage with TWKR and GTX 295 Quad SLI on M4N82 Deluxe:
http://plaza.fi/s/f/editor/images/am...age_p28426.jpg
Vantage CPU @ 5900 MHz:
http://plaza.fi/s/f/editor/images/am...e_cpu_5900.png
P30k needs +6 GHz on CPU with this platform. Very bad motherboard for extreme-overclocking (especially NB) so no more tests from me.
OK I give! Not to change the subject about TWKR but how would you go about getting engineering samples from AMD? I do work for a new company that sells gamers if that might help my cause... Thx in advance.
Thx for the heads up chew* :(
Nice job Sampsa! :mad: I think I can get a lil more from the ram. I will keep trying.
Thank you guys for all the useful info you guys post out there. :up:
Your chip will probably do those speeds we benched at Cobra.....nothing stellar about either of our speeds, Sampsa and I were just feeling out particular boards.....MSi has a back track record as sampsa already knows. I guess he covered that board......the search continues....as I'm still not confident about using the MSI with a good chip.
I have a few factors working against me. South Florida is one factor and only running on water. I do enjoy speeding hrs on end testing and benching so.... i may company expense some stuff in the future to try to keep up with the big boys :yepp: .
would you guys recommend this?
http://www.performance-pcs.com/catal...ducts_id=25622
For DI yes.....Ln2 no....However...I have some inside if on a rather affordable but awsome performing DI pot in the works.....via this company....it's combining effeciency with performance with bang for buck...it may even perform well on ln2...jury still out as it needs testing.
www.ln2cooling.com
Awesome. We tried this before with regular ice water. We should have gotten the bubbles out before dropping it in the cooler but its all for fun lol. The beer did stay cold.
http://img43.imageshack.us/img43/4002/img0858e.jpg
DI works with a rad setup as long as the mixture has a low freeze point and blocks have high flow....done it before with a dual pump setup.
Awesome ! :D I've been looking for result with Quad-SLi/3-way SLi on this motherboard and with a Phenom II X4 955 CPU.
By comparing I assume my system gets what it should get. I swapped my Core i7 920 GTX280 SLi system for PII X4 955 GTX280 3-way-SLi.
Cooler Master CM 690 nVidia Edition
AMD Phenom II X4 955 B.E 3.2GHz
Arctic Cooling Freezer Xtreme CPU-cooler
4x2GB Crucial BallistiX PC6400@800MHz CL4-4-4-12 2T @ 2.0v
2x MSI N280GTX-T2D1G Super OC & 1x Leadtek WinFast GTX 280 in 3-way-SLi
Asus M4N82 Deluxe motherboard
Samsung F1 640GB & Seagate 7200.12 750GB harddrives
Samsung SH-S203D DVD-RW+/-
Thermaltake Toughpower 1500w
score:
http://service.futuremark.com/compare?3dmv=1228544
Other systems score (the one to the right in the signature)
http://service.futuremark.com/compare?3dmv=1012137
I know it's with PhysX but I can't be bothered, why cripple the cards.
Thanks :p:
http://i95.photobucket.com/albums/l1..._3378Large.jpg
Cable management i know i know, but i did the best i could do in this case. The cables were really stiff and the ATX cable I could put behind the motherboard plate since then the case-panel couldn't close, so I had to put the ATX cable in the middle up to the sidepanel.
All the PCI-E cables are so stiff so I had to put them in the bottom of the case, they are obstructing a bit airflow from the 80mm fan almost invisibe, but it's there... it's better than nothing. Else the whole harddrive area and the area for the GFX and the CPU area i free og cables. The cables you can see are all placed right up the right left case-sidepanel.
The 8pin motherboard connector wasn't long enough to let ig go around the back... and I couldn't wait for an extension cable.
http://i95.photobucket.com/albums/l1..._3384Large.jpg
http://i95.photobucket.com/albums/l1..._3385Large.jpg
I put a Scythe Kaze Maru 140mm 1900rpm on the side panel (fits in 120mm mounting wholes), hooked up to a Zalman fanmate.
And don't worry I've cleaned the panel so no more fingerprints all over :D
Looks good :up: I can do a better job on a friends/customers comp on cable management but when it comes to mine.... well you know :D. Overclock the piss out of those cards. You are holding back on us :sonic:
