Antec 900: http://www.xtremesystems.org/forums/...d.php?t=211950
Does this one count? http://www.xtremesystems.org/forums/...ad.php?t=81758 :p:;)
Another Koolance (Chieftek) case from the past:
http://www.xtremesystems.org/forums/...7&postcount=24
Here's another all internal Antec 300 loop: http://www.xtremesystems.org/forums/...&postcount=126
--Matt
Great idea for the thread. I know high maintenance. But makes it much much easier to see all one stop shopping to see examples of your case options.
If anyone has any more pics of an antec 1200, it would be much appreciated. Thanks.
Didn't see my UF20 build I did, triple loop with Pedestal.
http://www.xtremesystems.org/forums/...&postcount=145
Stacked added.
Antec 900 added.
External fan. Not added. I like the build though. Very steampunk.
Antec 300 added.
It's a very nice build, but no.
Added.
Make this a sticky very nice indeed thread
@Zehnsucht, So the P182 doesn't count, everything is mounted on and at it in a way as sexy as possible ...
but this summer I'll try to put a second loop in the case, fully internal, will it count than :D
If you want you can add mine its a 120.3 modded into a PC-V1100.
http://www.xtremesystems.org/forums/...6&postcount=38
Another V350 fully water cooled internally to add to the list.
Project Citrus.
hrm this reminds me that i never did fix my cpu block ... ohh well
Great Thread. Helped me decide on the case for my next build....
Nice thread!
Although my worklog not finished, I'd like to say that Stacker 83x may carry dual loop with triple and double Thermochiils internally
http://www.xtremesystems.org/forums/...9&postcount=84
Found some dead links in there. Might want to check then out :up:
I love this thread, and I also vote it should be sticky!
Thx for this thread, it has served me a great purpose in picking up a case.
No.14 in the "unknown" section was my A71, though never properly finished more progress was made before it was broken down and sold:
http://i374.photobucket.com/albums/o...derdadesk2.jpg
http://i374.photobucket.com/albums/o...e/CIMG0444.jpg
Unfortunately no decent pictures as I fried my HDD's in an unfortunate drunken braiding session a few months back....
Oh my, this thread came alive again?
Well, I better get up to speed with the latest additions in the gallery then.
Also much appreciate this being done...I just learned that a quad goes in top of my case....really helps for researching for builds:up::up::up:
Unknown
10. Lian Li Lancool PC-7B
14. Lian Li PC-A71
19. Lian Li PC-G70
28. Silverstone TJ08
30. Lian Li PC-G70
31. Silverstone TJ07
