Great app, runs smooth as butter on my Asus F6V lappy. Only temperature values for the GPU though, but I think that's just because the lappy runs its video in a slightly different way. Either way, great work and keep it up!
Added link to new x64 version 1.1 with fixes!
http://www.hardwaremania.com/forum/d...1-1-0-x64-141/
Blackbox v1.1.0 x64
- Blackbox v1.1.0 has been rewritten. And landing, such as equipment identification functions are accelerated twice.
- Overclocking enthusiasts for the "o / c panel beta"
- Real-time "CPU voltage" information.
- Real-time in watts "processor power consumption" information. (CIP)
- Real-time "+3.3 v, +5 V and +12 V as" significant tensions.
- Real-time "DDR memory voltage" information.
- Real-time CPU and System fan speed on the other definable.
- Real-time "hard disk temperature"
- Real-time "Graphic Processor temperature"
- Graphic / Shader processors and graphics memory for real-time speed information.
- Board of the overall system temperature sensor.
- The processor on the motherboard on the sensors with the exception of internal algılaıcılar the processor temperature detection.
- All network adapters support for information and rates.
- changed with the new Intel processor logo.
- Motherboard brand logo information added.
- Italian language support has arrived.
- New Phenom II and the latest nvidia 740i chipset and processor support Corei7.
- Dozens of error correction.
Blackbox v1.1.0 x64 works fine for me. Just memory voltage displayed value is very odd, Asus P5Q board, and it shows 1.14 V instead of 2.1 V. :shocked:
Win XP x64 btw.
Hey people be sure to upload your current data to support future versions of this freeware.
(Under the about tab)
Uploaded*
BB x64 V1.1 works great here!
Amazing piece of software :up:
Great update for X64 hersounds! OC panel is up and running perfectly and it's detecting a lot more than the previous version.
Only minor complaint is that it's still not showing my motherboard manufacturer, model, or bios version.
Not that it matters, just letting you know. :up:
Now this one is working on both my quad and gainestown..
Now if that OC panel wasn't just a read but would allow me to actually OC the Gainestown I'd hug ya!:rofl:
With 1.1 it now detects my mainboard correctly:up:
hmmm 1.1 still gives me error's and wont start.... looks like a great app though :up:
1.1 works much better :up:
One thing... on the OC panel it shows voltage. Is that what the bios is set to or the detected voltage? Because it is readint 1.40V but my BIOS is set at 1.45V so I'm just curious where it gets its number from.
The PSU voltages are way off but that's expected, no software has been able to read the volts on this board properly.
waov i am proud of HARDWAREMANIA
Oh, awesome, somehow I missed this yesterday.
BB x64 1.1 gives me an error under vistax64.
Here I get :
"System.Exception: System.OverflowException: Arithmetic operation resulted in an overflow.
at BlackBox.gövde.ram_index_TextChanged(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnTextChanged(EventAr gs e)
at System.Windows.Forms.Label.OnTextChanged(EventArgs e)
at System.Windows.Forms.Control.set_Text(String value)
at BlackBox.gövde.bw_yükleme_DoWork(Object sender, DoWorkEventArgs e)
at BlackBox.gövde.bw_yükleme_RunWorkerCompleted(Objec t sender, RunWorkerCompletedEventArgs e)"
in windows 7 x64. Version 1.02 did load but was a bit crazy in cpu speed readings :(
if u have errors please check if the last runtimes are instaled like visual basic,.net framework,etc
Great tool! :)
However for me my GPU speed, memory, shader is not updating correctly on the overclocking page.
I'm running WinXP SP3 x86....
GTX280.
i like it alot thanks
Looks good, Im def. going to try this out once i get my i7 rig up and running.
1.1 64bit detects wrong GPU as main (have two installed). Overclocking panel shows wrong video card and no overclock options as well.
1.1 32bit overclocking options dont work on my laptop... not really surprised there though (i945/GMA950).
I like it except for 1 minor glitch. On my AMD systems it shows EM64T as extension.
I don't like that, because AMD doesn't use EM64T. It really troubles me.
So I'd like to see that change in either AMD64 or X86-64 but not EM64T, that hurts!
why this is moved to "Graphics and other programs" while every cpuz version stays on the news section?
