This thread just made me think of this:
http://erasmus354.googlepages.com/Whyitwontwork.jpg
So the question is ... why is your middle card not showing much higher temps? /sarcasm
wait wait wait, what Graphics card is that anyway? I thought it was the GTX285? :confused:
Ha ... I could be, I guess. BUT, given my luck, I'd bork something taking my existing cards apart, so I'll just live with what I have.
I think the point of this whole thread is that either way will work - I never saw where Hondacity inferred that his results were the best, and certainly that's not what I was saying either :up:
yeah its a lot of work to rig up a 3 way gpu loop once, let alone twice.
which is y nobody has done the comparison yet :)
unfortunately my ek gtx295 blocks cant run in parallel (although they do have parallel flow paths inside each block) or I would do a comparison.
shazza can you do a 1hr power supply test on your series cards?
i'm doing mine, this time XS style :) i'll be posting my results when this is done.
i'm drawing 1200w from the wall :rofl:
@all sorry been busy, i'll asnwer your questions, and comment on your comments later :)
I did run the PSU test for one hour - I have the graphs. Let me know if there's something specific you want to see. I saw a fair amount of fluctuation on my 3.3V and 12V lines -- seeing the 3.3 down to 3.07 and the 12V down to 11.45 or so. GPU temps climbed throughout the test - not massively, but up to 53 on one card, and 52 on the other two.
Can you clarify your comment, KaptCrunch? Not sure what you are saying about data not showing correctly.
shazza occt finished, but darn it only reported one gpu temp...i'll have to tinker around occt to get 3gpu temps...
edit: i found out gpu2 and gpu3 are disabled...ahhahah
can i ask an off question.
sorry about the slight detrail, but honda it looks like your running everest ultimate.
How did you get that program to play nice on a 64-bit i7? Skinnee and i were dying almost an entire day because that program kept crashing our i7's.
long overdue answer : yes it was from my flow testing
its 20C inside the apartment ...i'm getting load temps of 37-38c on my 285s. 50c :ROTF:
check part 2 at post1.
screenie on the new setup yes, single loop is gone.
log my cpu temps? thats too easy, if its odd to you. i'll say it to you ODD it is :)
you saying this as glitz?
vantage 3x285s
http://i24.photobucket.com/albums/c5/hondacity25/xy.jpg
its 32bit dude, i get some weird bsods with the ssd and 64bit
anyways post1 is updated somewhat
Part2
The important stuff : The RAD and FANS, quad for the cpu, dual quad for the tri-sli
http://i24.photobucket.com/albums/c5...city25/fff.jpg
First 20minutes
http://i24.photobucket.com/albums/c5.../20minutes.jpg
40minutes later
http://i24.photobucket.com/albums/c5.../40minutes.jpg
gpu1 graph from occt
http://i24.photobucket.com/albums/c5...ity25/gpu1.jpg
gpu2 graph from occt
http://i24.photobucket.com/albums/c5...ity25/gpu2.jpg
gpu3 graph from occt
http://i24.photobucket.com/albums/c5...ity25/gpu3.jpg
************idle temps aren't really that interesting, nvidia throttles the gpu speed to around 300mhz versus max set, temps go down at 300mhz
************restriction on these blocks aren't bad.
not bad temps for this particular parallel setup of yours...
not bad?
37 under load is :banana::banana::banana::banana:ing excellent in my books :up:
Awesome, Hondacity. Amazing temps - very interesting to see how well the 2 x 4 Rad setup does. I guess I will just have to live with 50C at load on my GPUs and their measly little PA120.3 - but nice to know what can be accomplished. And that CPU likes being on it's own quad as well. Thanks much for all this interesting stuff.
honda you sure have one insane rad setup.........
Sorry I guess I was a bit too vague in my post. In the last parallel Tri-SLI thread Naekuh was all over it preaching how it couldn't possibly work. How he had tried it and failed miserably. How the middle card wouldn't get any flow. That was actually HIS image that he posted, and the sad thing is most people in the thread went along with him, I guess Post Count >>> *. Because when I posted it people immediately jumped on it as being a ludicrous assumption to make.
Anyways great work, those Heatkillers really look slick and your temps are superb. We now have had no less than 3 people post excellent and EVEN temps using this same parallel Tri-SLI setup.
I'm not sure you have enough radiator capacity for this build :rofl:
Awesome tests Honda, thank you for taking the time to try and educate the community, it is greatly appreciated.
Nice Results!
So, after seeing this cooling setup,I was wondering if a Swiftech mcr320 with Medium Yate Loons, would be enough to cool the 3 285's?? I ask because I am putting my 3 under water next week.... Damn they get hot, with stock cooling and over clocked in tri-sli... :D
