that thing is way to big for me. i like the test bench i made.
http://img516.imageshack.us/img516/5880/imgp0435.jpg
http://img516.imageshack.us/img516/4827/imgp0436.jpg
So when and how could I get one of these in the U.S.?
Looks very nice! I want one.
is that's not all in one? :D:D
chiller for 0°C testing
+ watercolling
http://photodorp.com/images.php/i275_IMG1285.jpg
http://photodorp.com/images.php/i274_IMG1283.jpg
http://photodorp.com/images.php/i273_IMG1282.jpg
http://photodorp.com/images.php/i272_IMG1281.jpg
http://photodorp.com/images.php/i271_IMG1277.jpg
http://photodorp.com/images.php/i270_IMG1276.jpg
http://photodorp.com/images.php/i269_IMG1274.jpg
http://photodorp.com/images.php/i268_IMG1272.jpg
http://photodorp.com/images.php/i267_IMG1270.jpg
Nice, looks alot like mine...:D
Except I did 480's on each side..
http://img401.imageshack.us/img401/5...rklog13op4.jpg
http://img401.imageshack.us/img401/2...rklog14tz9.jpg
Nothing fancy, but it works well for my needs.:up:
gah...I need a new bench! This thread is making my wallet wince.
Nice case design. There really is some quality cases coming out these days, spoilt for choice :)
nice and big enuf to fit my ma's Karaoke machine...
maybe i can watercool that one...
but very nice..
love the pass thru's...
I just bought this case. For some reason seeing every picture include the 5.25" bay res, the res on the side and all the fan grills
http://img196.imageshack.us/img196/6...fronthwd01.jpg
I assumed that that came with the case. I could be wrong, but I thought normally when you are at a site that sells things and all the pictures shows the item you are interested in as having alot of different parts and nowhere does it say "xx part not included", then it is reasonable to assume that it comes with it. Especially considering it's $179. Well, appearntly it does not. Also, this case does not come with an On/Off or reset switch, so be sure you have other options to turn the computer on, otherwise you are SOL.
Ok, np. However mine came without the HDD rack as well and I should diffinently have gotten that. Gonna give it till maybe tuesday to see if PPC and Technofront comes through with mailing me the missing part, before I see about a refund.
Heres mine, waiting for GTX 295 to get back from RMA :(
http://img195.imageshack.us/img195/4249/dsc01215u.jpg
Will the Airbox 360 fit a TC PA120.3? I assume it is 15mm spacing and not 25mm spacing. I would love to get one if it does.
Sorry to bring up this thread, just wanna ask if the part below can be replaced by an metal version? Or does one exist? Thanks in advance.....
http://photodorp.com/images.php/i264_IMG1215.jpg
This is the closest I have come up with. I have spent hours looking for bulkheads.
http://www.performance-pcs.com/catal...ducts_id=24000
Looks like nylon to me.
Thanks for the reply. Was hoping that there would be some metal counterpart for it.Quote:
Read in earlier post that they are PVC.Quote:
sure, you can use any "Schott-Fitting" or metal fillport for replacing those plastic connectors !
http://www.aquatuning.de/index.php/l...n/cPath/50_140
TFC fillport looks like it will fit...
Got a question for those that own the Tecnofront HWD. I am looking at buying one and want to make sure that my Rampage Extreme III motherboard will fit without hanging over the front edge as it is an inch deeper than my old x58 mobo. If anyone can take a quick measurement for me I would greatly appreciate it.
Sorry to derail... but lowfat.. how do those ssd's compare to revo's?
