:rolleyes: no it looks like aluminum. nickel plating is not dull. its shiny very shiny, and it doesn't allow for colors to be absorbed in.
i present to you
INNOVATEK.. cool-matic GTX 295...
http://www.webshop-innovatek.de/shop...01426_2_z1.jpg
http://www.webshop-innovatek.de/shop...1426_2e_z2.jpg
http://www.webshop-innovatek.de/shop...1426_2f_z3.jpg
http://www.webshop-innovatek.de/shop...1426_2d_z4.jpg
looks like the only difference between the two is the copper base... :( sad sad sad
Well, evil beat me to it by 5 minutes but yeah, that turd has Innovatek's crappy machining and flow pattern written all over it.
yay i win! wheres my cookie...
yea the way it was design it was obvious that i was made by innovatek.
atleast we can say that EVGA made a bad decision and that it wasnt there fault entirely.. :shrug:?
*snip*
didn't read the rest of the thread, came back to my computer, forgot to refresh ::P:
well we'll if this is real when we see it on the shelf.
i have to ask though, did EVGA machine their own blocks back then? were their first two waterblocks the aformentioned blocks?(680/8800GTX/ultra)? was it the case that they started machining their own to sell, instead of letting another company(innovatek) mess it up a third time. the copper bit was a bit suspicious though. where the old blocks copper for the core matrix, or straight aluminum?
Don't know what's wrong with metal mixture in a loop. Had loops working for over 2 years with blocks from Innovatek in Aluminum and EK in Copper and never ever had a single spot of corrosion. It's all in the cooling fluid...
Anyway, back on topic... That product should have never been advertised as Hydro Copper, it's fooling the consumer and we all know Copper is a better heat conductor and works better (and is more expensive as well) than Aluminum. Looks like a fail :down: to me.
Pretty sure it's out there somewhere.
http://www.archive.org/web/web.php
+1
You can mix metals just fine as long as you don't as you you use proper cooling fluid/additives. I mean every other car cooling system mixes metals, and they seem to be doing well...
Lots of people are also running Innovatek and Aqua Computer alu stuff with copper blocks and it works just fine (as long as they use proper additives of course).
I'm not saying that alu is good, but it's definitely usable in a WC setup.
Selling that block as Hydro Copper is deliberately misleading customers though, they should have never done that. Also, if someone sells alu blocks they should provide sufficient information on what corrosion protection should be used, which EVGA seems to not be doing considering the look of the block in the pics :down:
EVGA has been selling video cards with Innovatek blocks for years in Europe. Considering this there's no reason to doubt this. Also Fud is not really known for faking reviews, they may often provide dubious rumors that turn out to be wrong, but they don't fake reviews.
These additives are called corrosion inhibitors. Not corrosion blockers. Galvanic corrosion cannot be halted by adding in compounds, only slowed - any mixed volatile metals in a loop will cause corrosion. In order to fully protect yourself against any corrosion within the usable lifetime of the products, you'd have to add so much corrosion inhibitor to your loop that performance would suffer a huge hit - and you still couldn't guarantee anything.
Mixed metals are definitely not "usable", unless you like gambling with your hardware, and especially not when there are Cu variants available for more or less the same price.
Well, now EVGA has this gem under their belt too!! http://www.evga.com/articles/00467/
WOW, 197 Euros for that Aluminum POS??
/golfclap
Seriously, people will never learn
As much as I hate mixing metals, I gotta disagree with you on this. Mixing metals is not ideal but "OK" with the proper corrosion inhibiter. Adding more corrosion inhibitor than necessary will not extend the life of your product. A product's life cycle nowadays is what?....6 months to maybe 2 years max? I agree, you _will_ lose out on performance from using coolant instead of straight distilled but the drop will be minimal for most users.
That being said.....mixing metals in a loop is one thing...mixing metals in a single block is another....what a piece of crap....
How do you explain that people have been running mixed metal loops for years with no problems?
Why do the radiators and other parts of the cooling system in cars work for dozens of years if corrosion is such a problem?
Because of the "don't mix metals" hysteria on XS you don't find many people doing it here, but many German companies have been selling alu stuff for like 10 years now. How do you explain that these companies still exist if their products are not usable as you claim?
Sorry, but you obviously don't know what you're talking about.
PS: I'm not defending EVGA here, this product and the way it's marketed sucks. I'm jsut saying that alu is not inherently bad. If price and performance are right then there's no reason not to use alu with a good corrosion inhibitor. And this is coming from someone whose Swiftech Apogee GTX top suffers from corrosion (no inhibitor used though, I know what to do next time...).
yeah ur right i dont know what im talking about..
Just like this wasnt corrosion eh?
http://i125.photobucket.com/albums/p...a/IMG_1156.jpg
The point is to avoid that, not delay it.
Mixing metals with AntiCor coolant will delay that, skipping it will avoid it entirely.
And its not happy or nice when you got that and you need to clean it up from your loop.
Its called lack of real competition, and grossely messed up testing methodology.
dude dont even try to defend germans here unless its benz porsche or bmw.
wasn't that steel?
corrosion is still corrosion.
it involves mixing of metals.
if it was alu it would of been the same result.
im showing him that its possible. (because he said We have no idea WHAT we are talking about right?)
Oh and that company fixed that mistake, not much can be said about the germans.
(im not very happy with german h2o people, there low flow bs and messed up testing methodolgy is spreading like virus).
are you saying in europe they sell these cards w/ innovatek blocks because its cheap, and in america they sell them with their CU blocks? i haven't even seen an aluminum block on an EVGA card in the states. maybe the review is of european sample. :rolleyes: i really hope they didn't botch this up, otherwise thats a lot of respect lost from watercoolers, tis a shame as well because their FC GPU blocks were really top notch.
gives them even more a reason to hate us now eh chruschef....
us fat americans get all the best stuff and give eu the second par stuff? :rofl:
^nickle this is what your implying more.
