s0lid, you are awesome. this is a great build log, keep up the good work and keep feeding us those pictures!!
i take it you are an electrical and/or computer engineer?
More pics...
But damn it one part didn't come out as i wanted :shakes:
Since getting rad in there is kinda tight fit there were no other options...
http://s0lid.bx.fi/kuva/powermac/DSC...size=1280x1024
Not much todo anymore.
Little cabling job, sleeving and getting all parts in ^^
Well it's time to get this done ready :)
There isn't much work needed to be done:
Finish front panels cabling
Finish HDD/DVDs power cables
Install the parts
Final part list:
Athlon X2 7750 BE
Asus M3A76-CM (no HDMI but 10e cheaper than M3A78-CM)
4GB Corsair 800MHz XMS2
8800GT 512MB
160GB+250Gb
500W Nexus NX5000
Not 2 much hole between rad and fans?
Well little update:
Did 10mm shroud for rad.
Not perfect but should direct most of the air flow into right place :)
nice keyboard :p
Yay parts:
Testing psu, nope haven't been tested before. Fans are attached with superglue, hopefully they'll last over the next weekend (lanparty \o/):
And pieces put together:
http://koti.mbnet.fi/ipe91/IMG_4477.JPG
2 to lanparty :o
SRY my imagehost is currently offline due server software updates :)
Hmmm looks like i've forgot to add the finished pictures :)
http://s0lid.bx.fi/kuva/maccivalmis.JPG?size=1280x1024
Will add more later since i've changed GPU to HD3850.
Looking good!
Here's a shot of the front panel power pinout from when I did my G5 mod. I just soldered to the middle and far pads, and didn't touch the closer of them (I marked the pads I needed to solder to with a sharpie).:
http://i36.photobucket.com/albums/e1...1228Custom.jpg
Here's my Build log in case you need any more idea's, though I think you pretty well have my mod beat.
I loved the G5 I modded so much that I am getting another one to mod this Christmas break, possibly with watercooling, and some other goodies.
