Thats a good thing! As the phobya block proved with its 1mm base, heat is transferred much quicker with a thin base.
Makes my GTZ look like a a Thermaltake block :(
Wow thats a fantastic looking block. Too bad it doesn't use the 1/2" compression fittings. I would've considered this block for my i7 build coming up. I'm still thinking of either the koolance 350 or dtek v2 though. Still would like to see the results of the block.
@mcoffey
did it come with English Manual?
ooh ok mine didn't seance i ordered it from Germany but Rico sent my the manual.
http://www.sidewindercomputers.com/bishsiro45bg.html If you buy a couple of these you can use your 1/2" compression fittings!
I found these on effizienzgurus.de not too long ago IIRC. They were posted by Bundymania.
http://img.photobucket.com/albums/v3...g_6357e7kx.jpg
http://img.photobucket.com/albums/v3...g_635659d1.jpg
Very nice! Looks like the 1/2" fittings are just a little too big though :(
http://4.bp.blogspot.com/_rzJHDdHabL...ing%2Bbaby.jpg
Nice job!!
Gr Yil
any updates andy?
I got my block from Sidewinders today. I really like it so far, it's aesthetically pleasing, has good instructions, great mounting mechanism, solid backplate (although optional), and fairly minimalistic.
I can't speak for the thermals but it's damn sexy.
Here are a few pictures:
http://img.photobucket.com/albums/v2...a/IMG_3786.jpg
http://img.photobucket.com/albums/v2...a/IMG_3790.jpg
http://img.photobucket.com/albums/v2...a/IMG_3782.jpg
It should be against forum policy for you guys to post all of this goodness, jeez.
So can my compressions fit on this waterblock?
waiting for some temp #'s is killing me! :D
I got mine this weekend...I think I might get it nickel plated since I don't have a loop to add it to at the moment while I wait for new gear to arrive :D
It's a heavy block! Very solid and nice construction. I got the backplate for it as well.
Sorry for the less than stellar pics, but the lighting wasn't great...
http://img.photobucket.com/albums/v3...k/DSC02430.jpg
http://img.photobucket.com/albums/v3...k/DSC02431.jpg
http://img.photobucket.com/albums/v3...k/DSC02432.jpg
http://img.photobucket.com/albums/v3...k/DSC02433.jpg
whats the material used on the HK 3.0 LT? can you nickel plate it?
