Originally Posted by
soundood
i am running the same sticks as you, i also have 2 x 2 gig, and as far as i am aware this is the exact same chips that are in the reaper 1066's.
as for 8 gig? im not sure, i would expect it to work on this board, as it seems solid enough, and also has no disclaimer as such in the manual to suggest there could be issues.
the differance between 800 and 1066? from what i have seen not a lot, tighter timings can companstae for the mhz differance (i have both the gold OCZ 800 mhz(8 gig) and plats 1066's(4 gig))
@chew* did you notice any noticeable differance with the mem clock skew set to +300?, i remember you mentioning it somewhere?
i currently have it set to -300 on channel A (mem slots) and all seems good, did you get higher clocks with the advance 300?
