Sure, man. It's your right to believe that everybody in the world shares your narrow-minded viewpoint. What specifically is wrong with Vista? And in what areas does XP work better?
thats a repost
http://www.xtremesystems.org/forums/...&postcount=145
Just use Server 08. Server 08>XP>Vista. Done deal.
I'm only interested in CPU performance :clap:
You can turn Aero on. I don't use it. I find it irritating.
They say Server08 is same codebase yada yada... but why the diff?
Following shows some OS against each other. I think ServerEnt is Pre SP1.
http://dl.getdropbox.com/u/600721/PerfRessmall.gif
i run windows mobile. it is far more efficient with my 4 gigs of ram and quad core cpu and gtx 260, components that vista64 never gets close to challenging in any form.
:p:
There is no Pre SP1 2008 Server. Windows 2008 SP0=Vista SP1. 100% identical base code.
Also you compare the OSes thats tweaked for 2 different purposes. Remove areo etc in Vista and try again.
With Windows 7 the server and client OS will be on the same service pack level again so to say. Windows 7=Server 2008 R2. But with Vista and Server 2008. Vista got +1.
Ah right. Wasn't sure about teh SP1 for 2008. ;)
Cool charts, riptide. Now please tell use what variance can we expect in these tests.
