Originally Posted by
neo mike
There is no way its going to run on your striker 2 extreme at 2000 1.65, you will probally have to get up in the 1.9 area i would think. So eva2000 are you saying it wont run on other boards x48, x38, p45,790i , i have heard of people running x58 memory on boards other than x58, or are you just saying not at 1.65v, which i knew it would never do that, but should run at 1.8-2.0 at same rated speed.
My other question is running the i7 memory at 2.0v if thats what it takes to run at rated speed, going to fry the chips ?, all the good memory being made now is for i7 x58 boards, im not ready to go there yet.
Tell you what slim, i will go to frys and buy a tripple channel i7 kit, and try on my board, and we will see what happens, how much voltage it takes to reach rated speed, and go from there, thats oneway to find out for sure, then i can just return it.
