ok, i was going to max at 2.1v so thats cool, and im going to use Ketz modded bios to reduce over voltage by the motherboard to be sure. then comes the overclocking lol
Some mobos (like my Abit Pro) won't allow user to set PL
How high will they go at cas5?
Lookie Here:
2x1GB D9 PL5
http://i383.photobucket.com/albums/o...achemem10k.png
2x2GB Powerchips PL6
http://i383.photobucket.com/albums/o...achemem2x2.png
Very nice mate,Honestly I think you might go for an extra voltage,pull it to 2.25V~ and oc it as far as you can.
just had an hour to play with the G.Skills and got this, i havent tried anything higher than 1000mhz yet, so just timings play.
got them at 1000mhz 5-5-4-13 @ 2V gettint 8200mb read, 7200mb write and 7800mb copy at PL8. at PL7 i get memtest errors.
so cant drop the PL anymore. what else could i try?? lol cant beleive i did quite well with the corsairs before.
I'd try higher volts. Manufacturers sell lots of sticks with stock volts at 2.2 :). If you have a fan, stick it around there, memory diesn't dissipate much wattage, so cooling it down is easy.
yeh i upped voltage to 2.1v, and used Kets modded P5Q deluxe bios 1403 and it pushed read to 8400mb, write to 7275mb and copy to 8050mb. got trfc to 48 from 60, havent tried lower and other timings are as low as possible from bsod lol and memtest and prime95 stable at 1000mhz.
should try 1066mhz, how much difference will it make?
