yeah, cpu power is not everything:)
Whichever turns out to be the best it does seem to indicate that we might prolong this burst of new high scores, which I'm sure you find as interesting as me.
Nothing worse than no new gpu or cpu coming out and things just sitting in the Doldrums. It's been a good end to the year for benching.
Regards
Andy
Not even close to 27k :PQuote:
GIVE DJ'S 25.9K RUN WITH HIS 9800P@535/410 AT 4400MHZ WIHT MACCI'S OR OPP'S CLOCKS OVER TWO MONTHS AGO AND HE BE CLOSE IF NOT AT 27K
His lobbys were about the same or lower than my 26.2k P4 run @4047MHz (with 1:1 2-2-2-5 RAM). Only his car hi was some 200Marks better. So that setup would have prolly hit 26.2-26.4k max with 580/425 Radeon clocks.
How would it not be faster macci? I can guarantee if that chip was in your board you would have it going a lot faster than 26.2k. Otherwise what would be the point of the EE?
This guy hit 26.1k using 3:2, an 865 board (no PAT) which is barely even trying.
I think it would be the best if you all post scores of default 9800 pro speeds so like that its easy to tell which cpu is the most powerfull. Overclocking the video card will never really prove which chip does better then the other if the video card is also overclocked. So why don't all the pople with amd cpu's and intel cpu's post their scores here with default 9800 pro speeds. Thank you.
I was talking about the score Mickey mentioned there (DJ's old P4 4.4GHz with high video clocks).Quote:
The EE obviously kicks some butt but thats another thing.
How about this run by OPP at 4390MHz with 587/410 card clocks...only 26.1k :PQuote:
Just comes to show how much bandwidht means there.. P4 @4GHz with high bandwidth (1:1 TURBO timings) can beat a 4.4G with 5:4 mem divider in everything but Car hi test ;)
http://www.solidhardware.com/macci/p4s.gif
Latency is King. :)
I still think a P4EE @ 1:1 + 875p will perform better.
bump
someone sticky this thread it is very useful
