I love XS too much hahahhaa
That was a nice read STEvil, thanks.
From the results he achieved on a dualcore, it is very possible that system would be able to handle a quad moderated overclocked. But there are 2 large TEC's and 2 TRUE's there. But it might be possible, only if he tests it on quad we would know. On a high overclocked quad, it would fail.
I have played with TEC's before, and I can say, that system holded a low temp on the cold side, because the load of a 45nm dualcore at that vcore and 4GHz is still very low. Once you go increasing the load on the cold side, the TEC will be losing its efficiency very fast. Meaning the hot side needs to be cooled better, or the system will get out of control, and perform worst then the same system without the TEC's. On a quad at 1.6V and 4.5 - 5GHz, things are much different, the heat of the CPU is twice more, and the TEC's fails miserably with cooled with air, no matter what cooler. No aircooler would handle the hot side well, to keep the TEC on the efficiency part of the chart.
If there is no load, you can cool a 2000W TEC with air if you want.
With little load (heat) of a 45nm dual core at 4GHz or so, you can still cool the TEC with air, as that link showed.
But you start raising that load (heat), and you will see how fast the TEC will lose efficiency. And the only way to get it back, is to keep the hot side closest to ambient as possible. And aircooling won't be able to do it, at a certain point.
I say it is impossible to cool TEC's with aircoolers, and use them on high overclocked quads. We are talking about 250W - 300W load from CPU + the TEC load which can be arround 200W LOL! No way to do it with air.
[]'s
Simps
wow people seriously stop whinging...
look if you want this buy it... it may beat TRUE if it does then fair does
if you want to stick to TRUE then fair does do that.
Why :banana::banana::banana::banana::banana: about something like this lol kinda sad... fanboi isk?
cut out along post out.
do people reach 4.2ghs on air with I7 ?
that's 10 watts for every 100mhz
Phenom II looks to be 8.75 watts for every 100mhz
lastly I had a phenom 9850 dumping out heat on my sunbeam CCF in fact the heat sink got up to 41C. right now with phenom II 940 I haven't seen it go above 33C. with the same volts as the 9850.
the old phenom 9850 used a lot more power just for 3.0ghz because I needed 1.4875 volts. (vista 64 bit)
I think the TRUE is probably one of best out there. But you need to lap it, and washer mod it to get to that point. Its amazing its been this good for so long.
Ive seen the reviews of the Thermal Lab Baram. Looks to be very similar to a TRUE overall, even showing good improvements using 2 fans. I wish they would get some in the US to buy. Id give it a shot.
I do want to see some results for the new Xigmatek Thors Hammer. 7 heatpipes, 4 8mm 3 6mm. Looks like a winner. Can handle 2 fans. May be the next best thing.
I dont care for the looks of the V10. Somewhat stupid looking IMO. The V8 is a decent air cooler, but huge is the word.
would it be possible to lap down the contact area, until you get a heatpipe direct touch?
How loud is this monster?
All V10 numbers are being withheld until embargo is lifted :S
That's just not fun at all :(
The V-10 is amazing!!! Makes me think that we reaching the limits of air cooling...I mean, carbon nanotubes and 200cfm fans aside, there is not much room for improvement.
Watercooling is just another method of moving thermal energy into the same environment aircoolers dump heat into :cool:
The basic reason it's more efficient is because of the general lack of size limitations for the radiator and because you can use forced flow in the tubing rather than the passive heatpipes we have in HSFs. :yepp:
Someday though....it'll all collapse into basically the same performance envelope (radiator size in aircooling will probably end up being the bottleneck that keeps it from being totally equal) :)
When will we start seeing some V10 #'s? I am not sure if there was a date indicated when people could start posting them.
thanks,
Eddie
Few numbers for the V10 that people might find interesting:
41, 140
(day of the year it launches, MSRP in USD)
