With threads like this we see why your name is in green!:up:
One of the few people here that have a total understanding of the systems and why you get what most can not.:clap:
sure am look at this pi efficiency
Best 32M Pi effiency I've managed to date = 3864.4 x 550.891 seconds = 2128863
http://fileshosts.com/intel/DFI/DFI_..._sgeverest.png
thanks.. sure is... systematically test every part of the system then combine what you've learnt :D
yeah G.skill still keeping up
CPUZ Validation
@DDR3-2247Mhz 8-9-8-22 at 2.025v bios
http://valid.canardpc.com/cache/banner/491726.png
http://fileshosts.com/intel/DFI/DFI_...uzvalid_tn.png
Heh that poor stick is flying, nice work. Nice SPI32M run too that's fantastic efficiency. Any idea how well samsung HCF0 IC's withstand vdimm like 2.025v long term?
Samsung HCF0 handled 1.9-2.0 fine on X48 and has no probs on X58 for benching. Wouldn't run it 24/7 though :D
did some DMM measurements and seems both BIOS, SG and CPUZ with vdroop disabled over report real volts - so above benchies were actually using less vcore than stated hehe
PSU = HX1000
http://nx.i4memory.com/reviewimages/..._utx58_dmm.jpg
http://nx.i4memory.com/reviewimages/...ble_draft2.png
- Vcore over reports slightly in VDROOP Enabled mode, but severely over reports with VDROOP Disabled i.e. 1.23v bios/SG reported = 1.206/1.203v idle/load DMM measured!
- VDIMM over reports by 0.005v
- CPU VTT undervolts by 0.012v to 0.014v at idle but jumps 0.009v higher under windows load but still is 0.005v under volted under load compared to what is set in bios
Very nice overclocking on air!
you going to push it on sub zero?
Thanks !
Eventually might try single stage 1/4HP (never used DI/LN2 before), but I usually take my time with a new setup air then water to get to know every part of the system - especially focusing on my favourite part = memory :D That and I still have my 2nd i7 920 3836A756 to test on same air cooling to see how it compares to the above identical batch sibling :D
I'm afraid a 1/4hp won't cut it.. my 1/3hp is struggling madly and it's already tuned for the highest possible load it can cope with (= 280W) ...
Of course, for your kind of short-load quick benching, it might just do ;)
