I returned everything to stock right now :P
it frustrated me that i cant get it stable...
heres my log over at TPU, it has updates throughout the thread, but the components remained the same as the first post.
http://forums.techpowerup.com/showthread.php?t=82607
I can do 4.3 GHz HT on, stable for about an hour and a half just for benching, I dont run the rig at that setting daily. voltage is not within safe specs. Only do it for short periods of benching.
http://i458.photobucket.com/albums/q...k4-u/cpu-1.jpg
here is a shot
What do u keep ur speed at normal use?
oh liquid cooling :P maybe i go that route later but i dun even know if i can push my cpu anymore cant even get a good oc with good air cooling :(
here are my daily settings, i have crunched over 86 hours with these settings, not one BSOD or restart or hang. I game, and bench on this too!
if you notice while browsing i am also crunching in the background. Rock solid stable dude:
http://img.techpowerup.org/090321/Capture117.jpg
I have it at this setting right now
BCLK: 200
Mul: 19x
Dram: 1603 ( 8x )
UNCLK: 3206 ( 2x )
QPI LINK SPD: 7200MT/s
Vcore: 1.35v
PTT: Auto
QPI: 1.35v
DRAM: 1.66v
can u show me your setting
but your doing water cooling so it shouldnt be a problem..
I'm still on air so i doubt i can get it stable with 4ghz
I'll be happy to get it stable at 3.8ghz with ht on :(
http://i458.photobucket.com/albums/q...ck4-u/cpu2.jpg
did as you say hope this work
my voltage is liek this
vcore: 1.35v
QPI: 1.35v
dram: 1.66v
should be okay>?
i have qpi link speed at 18 x?
i try to prime it now :( hope it works...
good. Looks like it was either your ram or your memory controller having a hard time being stable at higher clocks. Keep the RAM like that and go from there. If it continues to be stable, try to lower your vcore little by little. If you can be stable at lower vcore thats good. Lower voltage, cooler temps :up:
yeah i hope it run stable right now at like this than i'll try lowering the vcore
do i have to touch the qpi/dram voltage?
#1 - Where do you get F5E? Is it an official BIOS or beta?
#2 - I received my UD5 with F4 and flashed it to F5. Overclocked to 4.0GHz but now I can't get it to wake up from sleep (S3 suspend). I thought the issue was fixed with the F5 bios...
Computer powers on fine but the screen is black. I have to do a hard reset in order to get back into Windows. Any ideas?
Yeah :) just messing.
Well the Bios is all ok, Was working with the same settings as earlier F5 bios settings, no change in Voltages, atleast for me, and ET6 is working also.
Thought it was a good one, but then, it started, now and then when i were rebooting, it got to a blank screen and i had to reset and it got to OC failure screen. very annoying, So now i have switched to the great F5G that is working flawlessly so far as before, no bad reboots etc. only thing, S3 and ET6 wont work with this, but i never use Sleep so why bother, ET6 is not a must either, so im sticking with F5G so far.
Yeah, F5E is a beta bios, all bios'es with letters are BETA.. those without are the Final one, and check out Tweaktown Gigabyte forum for latest and all previous beta bios. great place actually got all progs and stuff you need :)
Well NO F5 Bios is working with S3, dunno if it's even fixed until now, many complains over it, only working i think is with F3 bios?
