haha yeah it was a tight fit, but somehow managed to squeeze everything in. cheers.
Its a great reward receiving all the complements on its completed finish!
I was replacing the white plugs with black ones today on the back... even though I never see them hahaha but I had them now so yeah... here is what the back looks like.
http://img25.imageshack.us/img25/9505/lain007.jpg
wow, AMAZING wiring job, there. Great work :up:
why the neoprene hose? you're going below ambient?
well thanks so much! Its great to have so much positive feedback! :D
Thanks, the wire placement worked out perfect. bit cramped but worked ha.
The holder are just cable clamps.
The place I got mine from is called Allied Electronics.
www.alliedelec.com
I got two sizes. The smaller one is part number N-2-BK-100PK and the larger is N-3-BK-100PK
and the screws are these babyshttp://www.mountainmods.com/632-25-i...ews-p-484.html, I just drilled where I wanted holes a bit smaller then the screws and away I went.
cheers!
Well I do live in Canada... haha nah im kidding. I just used it because the first tubing choice was out of stock and I still wanted black so I tried it out. Its nice stuff.
Fantastic job!
I tip my glass to you Sir. :)
Wish I had the same skill and artistry! nice job
Thank you for the kind words, I must admit I got the motivation and many of my ideas from looking at your beautiful builds. Must be the water in BC ;)
Thanks, there were many times when certain things didn't look like they would come out perfect. the side panel dvd-drive door was one... but in the end it came together. If you take your time you can achieve anything. Practice makes perfect.
Awesome build. I really like your style
Yeah I agree with lyl, this build has a style of it's own. Great stuff.
Wow I am jealous right now. Amazing work, I can't wait till I can get my WC rig going. I also hope it turns out half of what this is turning out to be.
Awesome work. Can't wait to see the finished product.
Hey, dang nice build! I really like the looks and how you integrated everything.
I was wondering, what kind of paint did you use, and does it chip easily?
As you can see, I have had some chipping issues with mine, if you look carefully at the bottom:
http://www.myzander.net/ATCS840/full...o/DSC_0355.jpg
Yeah thanks guys. My paint wasn't too bad. but if you want it done proper get powder coating, so worth it. I wish I had.
Im gonna call this RIG " Dark Knight" hehhe nice!
You're right. I should've thought of that. I'll do that when I watercool because I'll have to re-attach a lot of stuff anyways. Any recommendations for a good touch up paint that can be brush painted? Or should I just take it all apart and spray again?
Also, is there a clear coat protectant that won't make it glossy? Thanks again!
Jokester_wild, first congratulations on wonderful work you did in this case! and I would like to know which model and brand of your internal LCD and where you bought!
Thanks, its a VL System L.I.S 2. You can usually find them on ebay for a good deal. Heres the company website http://www.vlsys.co.kr/
Amaaazing build! What are the lengths of the socket cap screws that hold the radiator in place?
Can you tell me how did you get your photoshop done? thank you
