This will also change with AM3 CPUs because they'll get the TSI (Thermal Sense Interface).
1.1875 CAN'T RUN SP2004x4
SO.....VCC SET 1.25V
RUN SP2004x4
http://www.coolaler.com.tw/toppc/940/3G125V.JPG
standby
18W
http://www.coolaler.com.tw/toppc/940/3G125VW2.JPG
FULL SPEED SP2004 x4
65W
http://www.coolaler.com.tw/toppc/940/3G125VW.JPG
MAX 5.7A
68.5W
Looks very good!
Thanks Toppc! :toast:
多谢楼主!
功耗好可观阿。。。功耗测量全是 1.25v,还是1.35?
Am I getting this right 88W at 1.35V and 65W at 1.25V. Good one. Thank you very much for testing, no need for other reviews now. :)
Here an Q9300 oced to 3GHz requires 66W.
http://ht4u.net/reviews/2009/amd_phe...40/index14.php
@Toppc
I see you are running 1.6 volts on the cpu. Is it possible to go higher then 1.45 volts through the bios with Phenom II? I like my DKA790GX Platinum, but the 1.45 volts maximum on Phenom I in the bios is a bit low.
I assume it was done without ACC also. Have only read lostcircuit review. Skimmed ober anandtech, the chip has four p-states now? I'd love to tweak em all.
Think in idle it can be brought down to or close to (>5W) k8's 45w idle consumption.
@Toppc, Have you tested 1.185V with or without ACC? May work at 1.185V with ACC at -2 or 0.
how big of temp diff between stock cooler and xig? at load and idle?
1,45V limit is probably only for X4 Phenoms (I). On X3 you can also set voltage to 1,6V in the BIOS, but 1,55V or more require better cooling for motherboard power section (i.e. additional fan).
http://forum.pccentre.pl/uploads//12..._222_87430.jpg
Nice tests! Good to see the difference between the coolers! :)
What the FSB max on your MSI Platinum with you PII?
