The VTT Voltage :D
I think it's high but because you use x4 memory multiplier.:)
yeah high ram clocks need higher CPU VTT especially in 3d benchies, 2d/pi apps can get away with less volts but it also depends on ram used. Better ram may allow less CPU VTT required from my early tests - won't know more until I get to test other memory configs out with different ram.
Damm nice scores !!!
But did you disable HT to get 4.5 ? what is the max speed you can run with HT on ? And what is the max stable speed on stock volts with HT on ?
Keep up the good work !
see screenshot for cpuz HT enabled would = 8 threads , HT disabled = 4 threads :)
Hey guys,
just finished with my build an hour ago (DFI x58, i7 920 3838A, 6GB CSX Diablo 2000, custom SS).
My oberservations so far:
1. My CPU just hates the 20x mult, it won't even boot at 4Ghz with it
2. It likes the 19x, so far I am primestable at 220x19 using 1,42V Vcore and EVA's bios template, thanks.
3. Turbo mode doesn't work.. whether I enable or disable it there is no visible effect. Mult doesn't change under load.
So I think I need a new bios to fix that turbo issue... maybe my CPU likes 21 better than 20. Which bios can you recommend?
Are you sure you have enough cooling? I know other Stuttgart products need to run their fans at very high (and noisy) speeds for cooling, especially in traffic.
Lol? WTH are you talking about :confused:
It's -15C outside right now :p:
Anyway flashed to 0106 bios and turbo seems to finally work... back to testing I go
to enable turbo you need to enable EIST too
might want to read http://www.xtremesystems.org/forums/...&postcount=130 as well
Great work, Eva. Keep it going!
