Just wondering, did you test your RAM for errors before this fan setup?Quote:
Edit: Above setup killed the ram in the 1st slot. :( Praying the motherboard is still fine.
Installed the ram in another computer and ran memtest, errors galore. :(
Any suggestion for another air cooler for this motherboard ('cept for stock that is) or use a 120x20mm fan like what Eidos is using http://www.xtremesystems.org/forums/...7&postcount=35? A friend in Japan uses a Scythe Mugen2 and is having the same problem.
