Air cooling? That's not how you were raised, now is it? :D
nahhh, sure that's not what I wanted to do this WE but I am on business trips over and over in december and could not even make it once to my DICE dealer during the last 5 weeks (think he badly misses me :D ) - but wednesday I promise I'll get some cold and start real kickin' what everbody want's to see :) Hopefully my DICE dealer is not yet in christmas holidays, I don't think so but you never know...
ok guys now we go the right way :D this chip rocks under cold :up: this setting is currently running 32m :eek:
http://s11b.directupload.net/images/081217/eejad55b.png
:eek: Is cpu-z right about the voltage?
Is that on Air or WC ? thats still awesome !!!!
man them things really like being cold... i think i might go to water on it, ill have to see how my xig s1283 does on it first.
nice score SoF :D:D
have you got any system pics ? ;)
Putting 2 and 2 together....I think it's under dice guys.
Since he just got a bunch of it.
maybe that was in another thread I was reading...
god so many deneb threads in here to keep up on it gets confusing.
yeah it's DICE - system here albert :)
http://s11.directupload.net/images/0...p/juqdudbw.jpg
quick 32m here - it goes higher until 1.7V. for more LN2 would be good, this likes cold as hell. I am running against a wall around 5 gig but still awesome :up:
http://s11.directupload.net/images/081217/643gwqt6.png
validation not possible again like on my old Phenom :mad:
http://valid.canardpc.com/show_oc.php?id=464809
http://s11b.directupload.net/images/081217/ha4c4ddy.png
Darn that sadens me weirdly, I had hope for seeing 4.5 on water if it takes dice to reach 4.7 that seems unlikely.
LC Nab you have to consider the fact we've seen 4.0 and 4.2 floating around on AIR. Water tends to add a couple hundred more mhz.
Yeah I thought you could reach 4.x or near five ghz on water T_T .
try set ht link to 5x or below see if it clock any higher on that dice
im thinkin 3.6-4.0 on air, 4.1-4.5 on water, 4.6+ dice etc
the V's he used on 4.7ghz seems like they could be reasonable under good water from what weve seen on pI and what weve been hearing about temps on pII
Mmm maybe on the new dragon setups watercooling the NB and SB could be a must if you plan to OC the heck out of the deneb . Or i could be wrong but still I would wc them both just in case :D
ya the nb at least, i think it would be pretty hot if it kept enough V's to stay @ ~2500-2600 24/7
I hope foxcon can fix it on the new bios... ;)
Anyway this is the old method we change the ht link with wpcredit for AMD K10 processor
http://www.xtremesystems.org/forums/...&postcount=554
http://www.xtremesystems.org/forums/...2&postcount=26
Awesome teasers SoF, thanks for sharing :up:
I'm just wondering about the temp's, isn't there supposed to be a coldbug @ ~ -70°C without ht 1.0? You seem to be somewhat lower if I'm not mistaken.
Sof that 5.04 without being able to use ACC right ? . If that so that a dran good overclock without any acc help .Hopefully that will be fix with the new bios up date. :clap:
as far as I know you don't need ACC for better oc anymore. I have a friend doing a bit better than me on Destroyer - 300 HTT :eek: ACC is off all the time. thanks for the hint tictac.
SoF, hmm picture shows 2xradeons ;)
did you tried some 3d marks ? :D:D:D
hmm, it's good to hear acc isn't important for oc ;)
destroyer - goood mb :D
Yeah I have 06 at 4620mhz until now - does good in some benches but I need a third card. think I will make myself a christmas present :D
there are scores for people (like on c2q) or much lower ? :D
tell us please ;)
SoF, add to your Christmas presents list better DDR2 memory please :p:
420MHz and only 5-5-5?? get something which will do 3-3-3 :yepp:
