i cannot see the option for turbo mode in the bios, so turbo is 21x multi right??? or is there more to it, and where in the P6T bios is it, using 0804, currently sitting at 3.2ghz @ 1.1v
to use turbo on p6t, just stick the multiplier to auto.
I wish I could give you some hands on experience but my Core i7 920 has just left Toledo. The next best thing I can do is tell you that I will be looking in the Ai Tweaker menu for this ...
Intel Turbo Mode Tech [Enabled]
That option should enable or disable the Turbo Mode according to the manual.
From one review this is how they achieved 3.8GHz.
Ai Tweaker
Ai Overclock Tuner: Normal
CPU Ratio Setting: Auto
Intel SpeedStep Tech: Disabled
BCLK Frequency: 190
DRAM Frequency: DDR3-1523MHz
CPU Voltage: 1.35V
DRAM Bus Voltage: 1.66V
They did this with the Turbo modes off. I'd like to see what happens when it's enabled. I'll have to wait until Wednesday to find out.
nice m8, batch?
