If it only performs as well, what kind of "upgrade" would it be? :shrug:
Some people just change system because the want something new and different from what they previously had, though they are probably a minority. Although I can imagine that most will want to change clothes quite often, in that case the opposite is usually the minority :p:.
Yes but in comparison to clothes, it's harder to spot a new CPU when looking at a computer than it is to see my new pink collection of exclusive menswear.
No. There is no "if". Just no.
Deneb is just a die shrink of Agena, and at best will offer 5-10% performance improvement clock for clock. It's like the R600 to RV670... just a die shrink, with maybe some minor instruction set optimizations as well. How do we know this is the case?
AMD has said nothing about architectural improvements, because there are none. It's the same architecture, just a die shrink, with some very general talk of "25% performance boost". My arse.
It was the same with the transition from K8 to K10. AMD was silent on anything relating to architectural improvement, and instead talked about HT 3.0 and DDR2 and other things that don't really improve performance. And same with R600 to RV670.
But you notice that with RV670 to RV770, rumors of it's monster specs were flying out of control, and they proved to be true.
The only saving grace Deneb may have is ability to easily overclock to the range of 3.6GHz, but even now most Q6600s will go over that mark. And don't even try and compare Deneb to Nehalem ... it will be absolutely no contest. Nehalem is simply two or three leagues above Deneb in terms of performance, and it will rape (or is raping, I should say) in orifices that do not exist naturally.
it would want to considering the price of the mobo and chip. :p:Quote:
im keen on a deneb meself with one of those dfi 750sb 790 boards....maybe. at least i can afford this, although i am a little concerned about stability...
call it a fetish.Quote:
I'd be more inclined to compare K10 to R600 and K10.5 to RV670 - iow Deneb will be nowhere near the top spot but at least it will be a sensible mainstream option - and maybe a return to profitability for AMD (although not likely since it's about to be spanked in serverland).
Anyways I hope that AMD will manage to match Penryn clock for clock. Then AMD will at least have a reasonable platform for the desktop and mobile markets.
i wanna see deneb vs yorkfield.
003 stop flaming this is a DENEB thread.
It's already been stated several times that ipc it's 15-20% faster not counting the clock speed increase.
i7 is awesome no doubt but don't reign on Deneb just because i7 shows good promise now.
Deneb shows promise as well and until we get some good numbers don't go counting it out yet.
Not flaming, telling it like it is. I really don't care about intel or AMD, and I am not a fanboy of anything. Will deneb be a viable option for people in different situations? sure.
Will it even match kentsfield clock for clock? Nope.
Go on and tell me I am flaming, I honestly don't care. You will all see when deneb is out in the wild, so it makes no difference if you try and disagree with me at this point.
I'm sorry but I can't just sit around with my thumb in my ass while there is an entire thread of people who seem to think that deneb is going to match yorkfield or even kentsfield clock for clock. The difference between yorkfield and kentsfield is only 10% at best anyway, so people saying deneb will fall right between them are even more out of their mind.
i still wanna see deneb vs yorkfield.
:ROTF:
Black Edition :D
Assuming what you telling is true you already have working Deneb platform and done all sorts of benches Vs Yorkie and Kent. Perhaps you might as well share the results instead of showing us crystal ball ?
Just by dumb arithmetics Phenom+15-25% improvements will go toe to toe with Yorkie in most cases.
You claim this based on what? You do know that Agena is 5-8% slower per clock then Kenstfield?How can you claim AMD can't manage ever so small IPC gain(3x larger L3 alone can probably account for this)?
Simple question: Have you seen Deneb tests? Can you prove you saw them?Can you prove Deneb can't "match" kentsfield? If not you are flame baiting people here and trolling along the way.
edit:
Oh and since when has Guru3d become an "expert" site for CPU evaluation and testing? If one anandtech which has been around for so many years still can't be called that,how can Guru3d?(known mostly because of their GPU reviews and nothing else)
You are stating things as if they are facts, while there is no proof to it as of yet. Maybe you should on make predictions and when you do you should make it clear that you are doing so. Or you could provide hard proof or something, but for now it only seems to most other that you are flaming.
BTW, my prediction is a 10% IPC average improvement over Agena for Deneb, just a prediction though. That should put it right between a Kentfield and a Yorkfield, which would make it an interesting option for now. I've no idea how things will turn out for the next year though, I have this feeling that Deneb will pretty much loose its value once Intel launches their socket LGA1156 Nehalem derivatives.
Well you got me there I must say. Yeah, all the benchmark sites are wrong. How could I have been blinded for so long?? In fact, Agena is almost neck and neck with kentsfield as it is, looks like deneb will be a formidable competitor to i7 after all. Intel better be worried, AMD is making their comeback. :)
Guys let's just agree to disagree. Everyone has a right for his own pink world.
yup same here, i predict up to 10% IPC increasment for Deneb over Agena which will put it right inbetween Yorkfield and Kentsfield.
20-25% is just insane, maybe some rare cases (like spec_rate score, which to according to amd we all know is a "wide variety of workloads" :p: *scnr* ) but most of the time i doubt we see more then 10%.
Remember that Deneb is still the 3 issue architekture that barcelona was and 3rd level cache cant fix everything, espcial when you already got a IMC.
You asked if it was available. It was.
Would be nice if AMD could release the chips soon. But being quiet usually means there is no bang. Plus it might not be before 2009. I wonder if they stretch it like 65nm, just to be able to put a 45nm checkmark in 2008.
Also for people to expect 15-25% of deneb? Jeebus...Be happy if its 5%. 15-25% is more than K8->K10.
45nm K10s primary goal is to save them from the current suicide train in productioncost. The L3 less dualcore is also a demonstration of it.
shintai you do realize noone really pays attention to your ramblings because you sit there witing for an amd thread to come up so you can troll
I'm sure there will be wild debate as to where exactly Deneb falls on the IPC spectrum. I remember you doing the analysis on Agena a while back, but in the end there is no 'law' on what constitutes IPC and it really depends on the benchmark suite(s) used for comparison.
For example, in the recent 100 CPU roundup, Yorkfield is some ~30% faster than Phenom per clock: http://www.matbe.com/articles/lire/1...urs/page30.php
