I vote for that as well. Martin takes the time out of his days to do all the work to show us the real numbers. That speaks volumes in itself!
I feel like I'm simply entering a chorus, and I'm not even wet, but I always like to indulge myself in data. Thank you.
I guess it's time to make a new title. Xtreme WC Legend. ;)
Pretty awesome finale, Martin. Also, it makes my Fuzion V1 look so old.
http://www.xtremesystems.org/forums/...ad.php?t=59056
It's more for overclocking than anything else. I'm sure he's still plenty happy with XIP. A feat that is most difficult to achieve.
Sticky!!!........<ftw>
Amazing work Martin! and fairly easy to come up with a answer too (at least with the q6600 processor in mind specifically), EK block for single waterblock systems and Fuzion V2 for single loop multiple block systems.
Great extensive testing with great results. You outdid yourself just before you close the curtain on testing :up:
From the results, I will sit on my Fuzion v2 since 1C is meaningless under my eyes. I will just remove the quad mid-plate from what I heard around (Andy tested it to perform worse than the stock mid-plate). Any cpu block we recommend to new WC users is a good choice and it will actually vary depending on the loop setup (From cpu-only loop with RD-30 to multi-blocks loop with a DDC3.1 for silence).
Another vote for Xtreme Legend !
see thats not the point.
what is the best?
whats defined as the best?
To me the best is defined as the best. The best meaning the greatest possible.
I hope you guys understand that now. There is no brand favortism on my end. I love the supreme, but i hate EK FC blocks. I wil praise and promote the supreme till no tomorrow, but i will bash and destory the FC blocks.
You guys really need to understand that. When i say something is the best, im doing it very objectively, not favoratively. So I hope this review my good friend martin shows you guys that when i say something is the best, i really do mean it.
Since no one around me is even thinkn of i7, i decided to go back to my thermal testing. I have my own ways outside of martin, there not as precise, but its accurate.
Ancient Korean Technique passed down by generations. :rofl:
So when i come out with new predictions i hope you guys dont laugh at me again. :up:
Thanks Martin for the countless hours of testing. How could anyone put up with 5 times 15 variations of cpu block mounts??? 75 variations just on the block comparisons alone! :shocked: You did it, I know, cause you wanted to do it right! And as a result, EK has been vindicated in the eyes of many here.
When I started my first build, I poured over your site and XS looking for clues on how to do it right. Right now, I am looking at 28C idle on an overclocked phenom thanks to your tips, and a few from Waterlogged. I very much appreciate all your hard work. :clap:
Wow. Nice work, I'm impressed.
Awesome, as always. The neatly presented data doesn't nearly illustrate how much work must have gone into the testing.
Awesome work Martin! I really appreciate your effort. No more "product x is 4 degrees better than y!" they are all pretty close to each other. BTW, how thick is the ek surpreme fins+base?
Thanks for your hard work :up:
Martin your dedication and quality to the art of watercooling will always be appreciated. You have given so much of your time and money to be able to bring us good solid testing techniques that are not questioned.
I will miss your reviews but I fully understand the toll it must have taken on you. I raise my glass to you and your skills. :toast:
thanks martin!
Thanks guys!
No need for sticky, it's already in the reviews sticky. Anyhow, it's not like I'm vanishing all together, too many great folks in these forums. Nothing can take me away from getting my regular dosage of coffee or milk up the nose that I get here:eek:...too much fun!:D
Needless to say I'm not keeping just one block either, too many different types of processors out there and coming not to mention tweaks and nozzles and bowing, and everything else you can do to make them even better...:D
Cheers and have fun!!:)
Martin
This testing, and what I know about i7, makes me think that Fragarach, shuold it ever see the light of day, would do well on both. Maybe not top three, but it should be capable of handling either.
Now if I could only cast one...
Thanks Martin! Your honest results + meticulous documentation + sober analysis = huge resource for all of us!
Martin,
what stock volts is that Q6600 of yours? Do you have the coolant temps for the GTX?
I'd like to work out some c/w numbers and compare to "published" numbers.
