E8500 @ 4.5GHZ DDR1186 9.5H Prime Blend Stable
Got round to running 1 loop of Prime blend today, same 3D, Everest as before.
CN :)
DFI LANPARTY UT P45-T2RS (BIOS 1007)
INTEL CORE 2 DUO E8500 WOLFDALE 3.16GHZ 6M L2 CACHE (Q807A273 / C0)
OCZ PC2-8500 SLI 2 x 1GB PN:OCZN1066SR2GK
GECUBE HD4870X2 1GB (8.11 BETA DRIVERS)
1 X HITACHI DJ 80GB HD'S
SONY DUAL LAYER DVD RW (DRU-820A)
OCZ GAMEXTREAM 700W PSU
WINDOWS XP PRO SP3
CPU COOLING: WATER 1/2" TUBING, D-TEK FUZION V1 (4.5MM NOZZLE), LAING D5 VARIO, PA130.3, 3 X 100CFM PANAFLO 120MM FANS
Code:
>CPU Feature:
Thermal Management Control.......... - Disabled
PPM(EIST) Mode...................... - Disabled
Limit CPUID MaxVal.................. - Disabled
CIE Function........................ - Disabled
Execute Disable Bit................. - Disabled
Virtualization Technology........... - Disabled
Core Multi-Processing............... - Enabled
>DRAM Timing:
Enhance Data transmitting........... - Fast
Enhance Addressing.................. - Fast
T2 Dispatch......................... - Auto
>Clock Setting Fine Delay Press Enter:
DLL And RCOMP Settings.............. - Auto
Ch1 Dram Defaul Skew................ - Model 3
Ch2 Dram Defaul Skew................ - Model 3
RCOMP Settings...................... - Model 1
Fine Delay Step Degree.............. - 70ps
Ch1 Clock Crossing Setting.......... - Nominal
DIMM1 Clock Fine Delay.............. - Current[2396ps]
DIMM2 Clock Fine Delay.............. - Current[2396ps]
Ch1 Control0 Fine Delay............. - Current[268ps]
Ch1 Control1 Fine Delay............. - Current[268ps]
Ch1 Control2 Fine Delay............. - Current[268ps]
Ch1 Control3 Fine Delay............. - Current[268ps]
Ch1 Command Fine Delay.............. - Current[394ps]
Ch2 Clock Crossing Setting.......... - Nominal
DIMM3 Clock Fine Delay.............. - Current[2066ps]
DIMM4 Clock Fine Delay.............. - Current[2066ps]
Ch2 Control0 Fine Delay............. - Current[48ps]
Ch2 Control1 Fine Delay............. - Current[48ps]
Ch2 Control2 Fine Delay............. - Current[48ps]
Ch2 Control3 Fine Delay............. - Current[48ps]
Ch2 Command Fine Delay.............. - Current[394ps]
Ch1 Ch2 Common Clock Setting........ - More Aggressive
Ch1 RDCAS GNT-Chip Delay............ - Auto
Ch1 WRCAS GNT-Chip Delay............ - Auto
Ch1 Command To CS Delay............. - Auto
Ch2 RDCAS GNT-Chip Delay............ - Auto
Ch2 WRCAS GNT-Chip Delay............ - Auto
Ch2 Command To CS Delay............. - Auto
Flex Memory Mode..................... - Auto
CAS Latency Time (tCL)............... - 5
RAS# to CAS# Delay (tRCD)............ - 5
RAS# Precharge (tRP)................. - 5
Precharge Delay (tRAS)............... - 10
All Precharge to Act................. - 5
REF to ACT Delay (tRFC).............. - 28
Performance Level.................... - Auto
>Read delay phase adjust Press Enter:
Channel 1 Phase 0 Pull-In........... - Auto
Channel 1 Phase 1 Pull-In........... - Auto
Channel 1 Phase 2 Pull-In........... - Auto
Channel 1 Phase 3 Pull-In........... - Auto
Channel 1 Phase 4 Pull-In........... - Auto
Channel 2 Phase 0 Pull-In........... - Auto
Channel 2 Phase 1 Pull-In........... - Auto
Channel 2 Phase 2 Pull-In........... - Auto
Channel 2 Phase 3 Pull-In........... - Auto
Channel 2 Phase 4 Pull-In........... - Auto
Write to PRE Delay (tWR)............ - 12
Rank Write to Read (tWTR)........... - 11
ACT to ACT Delay (tRRD)............. - 3
Read to Write Delay (tRDWR)......... - 8
Ranks Write to Write (tWRWR)........ - Auto
Ranks Read to Read (tRDRD).......... - Auto
Ranks Write to Read (tWRRD)......... - Auto
ALL PRE to Refresh.................. - Auto
>Voltage Settings:
CPU VID Control..................... - 1.53125V
CPU VID Special Add................. - Disabled
CPU VID Special Add................. - Auto
DRAM Voltage Control................ - 2.21v
SB Core/CPU PLL Voltage............. - 1.55v
NB Core Voltage..................... - 1.369v
CPU VTT Voltage..................... - 1.24v
Vcore Droop Control................. - Enabled
Clockgen Voltage Control............ - 3.60v
GTL+ Buffer Strength................ - Strong
CPU GTL 0 REF Volt.................. - 0.6225
CPU GTL 2 REF Volt.................. - 0.6225
CPU GTL 1 REF Volt.................. - 0.6225
CPU GTL 3 REF Volt.................. - 0.6225
North Bridge GTL 0 REF Volt......... - 0.6275
North Bridge GTL 1 REF Volt......... - 0.6275
FSB Vref............................ - Auto
Genie BIOS Settings:
Exist Setup Shutdown................ - Mode 2
Exist Shutdown After AC loss........ - Enabled
AC Shutdown Free.................... - Enabled
O.C Clock Fail Retry Counter........ - 0
O.C Clock Fail CMOS Reloaded........ - Disabled
CPU Clock Ratio..................... - 9.5
Target CPU Clock.................... - 4493MHz
CPU Clock........................... - 473
Boot Up Clock....................... - Auto
CPU Clock Amplitude................. - 800mV
CPU Clock0 Skew..................... - 200ps
CPU Clock1 Skew..................... - 0ps
DRAM Speed.......................... - 266/667
Target DRAM Speed................... - 1186MHz
PCIE Clock.......................... - 100mhz
PCIE Slot Config.................... - 1x 1x
CPU Spread Spectrum................. - Disabled
PCIE Spread Spectrum................ - Disabled
PRIME95 + 3x CPU-Z
http://i106.photobucket.com/albums/m...86/95HStop.jpg
EVEREST CACHE & MEMORY:(READ 10480MBS LATENCY 48.5NS)
http://i106.photobucket.com/albums/m...45266Strap.jpg
3DMARK2001:(SCORE 87004)
http://i106.photobucket.com/albums/m...6/3DMARK01.jpg
3DMARK2003:(SCORE 82125)
http://i106.photobucket.com/albums/m...6/3DMARK03.jpg
3DMARK2005:(SCORE 30424)
http://i106.photobucket.com/albums/m...6/3DMARK05.jpg
3DMARK2006:(SCORE 21432)
http://i106.photobucket.com/albums/m.../3dDMARK06.jpg
AQUAMARK 3:(SCORE 268,526)
http://i106.photobucket.com/albums/m...6/Aquamark.jpg
SHORT DESCRIPTION:
473 x 9.5 = 4500MHz @ 1.45v
5-5-5-10 2T @ 2.21V DDR 1186
