I just used the 3M command yadiyada strips to attach my window. If you wanted the window on the outside well then this method is some serious fail but looking at that u channel makes me think you didn't.
Wow, this is one cool build.
Great work!
Nice lighting, where did you get them?
Very nice work b@llz0r!
That RD30 is menacing in black.:cool:
I think you would save a lot of tubing if you went straight from the pump to the blocks, then from the blocks to the rad, then back to the reservoir. Running the tubing across to the radiator, then to the blocks, then up to the reservoir is a lot of extra tubing. Not that it matters with an Iwaki, but it might look cleaner.
Either way, nice rig. More videos! :)
looks really good b@llz0r. :D
are you planning on sleeving the cables?
TY, tubing is Feser 3/8
30cm UV Cold Cathode tubes... you can get them pretty much anywhere
Yeah good point... I routed the tubes when I was under the misconception that loop order was important and then never thought to change it.
Re piped it tonight, much better :up:
http://lh4.ggpht.com/_5JXSu5Gfgo4/SU...0/DSC03558.JPG
Yeah thats the next phase... now that ive got the layout sorted.
It will have to wait till next year tho as im off on xmas holidays tonight
Ill leave you guys with this final pic for the year
http://lh4.ggpht.com/_5JXSu5Gfgo4/SU...0/DSC03545.JPG
Moar Pics!!! Moar!!!
great project. one of the better ones ive seen in the worklog section. cheers!
Forget the pc, I see a hot asian!
really great computer build thread
what is score in 3dmark 06 ?
nice works...
nice work!in the back of the case is pump and reservoir or?
Great project looks alot cleaner not that you have re-routed the tubing.
Whats left in the project?
Nice build man:up: the RD30 is just a Bomb :rocker:
