So is it better in gaming than my all time favorite Auzen X-Fi Prelude?.Atleast looking at the specs what is your opinion?
You know they aren't talking about USB headphones, sometimes statements lose something when translated. This card has a high quality, high impedance headphone amplifier which can drive any headphones on the market that require seperate amplification. For instance models like HD600, DT880, AKG K240..etc.
The Asus GX2.5 stuff is a Gimmick and I've tried it for myself. IMHO, it is a Daniel K type hack to dodge flags or to show fake support. The X-Fi processes EAX that adds to DS3D or OpenAL. Either of these alone aren't bad but EAX make them better. Note, these are HW effects. Good sound along is not enough for Games.
Not much to disagree with you with except two things. Xonars are great for music and not so good for games. The other thing I disagree with that 5500 are low quality at best. No, I'm not an audiophile but most $100+ Bookshelf speakers sound better. Many HTiB sound better for about the same price do as well.
I agree with most of the other things you said here.
Hopefully there will be some listening impressions this week...
Cant wait.. looks like I'll be able to build a killer rig with either Corei7 or Phenom 2... patience.. patience....
I'm currently using a headphone amp that was designed for car audio, hooked to the 12V harness from the car battery, but instead I'm connecting it to the 12V line from my PSU. Nifty, eh?
Would love to see this compared to the Auzentech Prelude HD coming out in january
First, sorry I missed this one James. I'd easily go with one of those HTiB. Many like the Onkyo, and even JVC has a couple of nice ones. The best thing to do is listen to them first but that is not always possible. Also reviews are not always accurate either since no two people hear or experience sound the same.
http://www.hometheaterhifi.com/masterindex_htib.html
http://www.hometheaterhifi.com/volum...nkyo_s660.html
The one I've heard the and like just as much as the better much more expensive ones are these (others in this line as well that cost more).
http://www.amazon.com/Onkyo-HT-S3100...Entertainment-
System/dp/B0015M1BCS/ref=sr_1_43?ie=UTF8&s=electronics&qid=1229443014&s r=1-43
Starts at $189 or you can get the 4100 model for $244 and makes the 5500 a bad deal its current price level. As others have said you can add better speakers to fit your needs or taste later on. I like Old School Full range for stereo to first. These are then turned into big Mid range when listening in 5.1 mode. I'm an Harmon Kardon Fan, always have been since the 70's when Carver/Phase Linear stole my ear! This would do that sweet sound Card some real Justis.
I had Logitech 560z many others, I also have a non working set of Mega works 650's. I swore off computer multimedia speakers years ago and none shipping have me change my mind. Hell, I built my own.
Just a fyi, there is no magic ear. the only difference is audiophiles appreciate higher fidelity while others appreciate value (bang for the buck) more. I'm sure this card will be great to those who want great two channel audio out of their card with enough oomph to not require a headphone amp for the higher end headphones.
There is snake oil though, wood blocks to lift speaker cables off the floor anyone or how about $100/ft speaker cable/interconnects?
Well this is depressing... according to the official website
http://www.asus.com/products.aspx?l1...11&modelmenu=2
The 'amazing' 124Snr is only available if your headphone is recabled for RCA inputs.. if you just use your 1/4" jack, you only get the measily 110db.. not that impressive for most people after all I think.
Then there are other engineers who'll laugh at your first statement as well. EAX was NEVER meant for Recording Engineers. EAX is used to add to already simulated or fake sounds. Does little to Nothing for real recordings that it was NEVER meant for. EAX setup correctly on a half-@$$-ed system does just what it supposed to.. Too bad many times I've checked others' systems with it not even setup or not enabled. Once these are done I mostly get two reactions embarrassment or astonishment! Embarrassed because most of these folks should have known better. One guy's been building computers at least 7 years. Then the other group is blown away and are like what did you do? They THOUGHT it was setup or that nVidia chipsets were at fault. I've found that **MOST** Nay Says NEVER truely heard EAX in action.
There are a tons of folks who think most of the folks who ID themselves as Audiophiles are folks who fall for and buy snake oil! Yet, I love $10,000 Martin Logan Summits:up:Quote:
Originally Posted by Levish
Headphone amp? Find an old Harmon Kardon like my old 730 or better still a 930? Other Headphone AMPs will never sound the same afterwards. Too bad I don't have my old HPM 100's:(
No LOE, you got caught showing off your cluelessness and have to lash out uh? I don't need to get or go down in the crapper gutter with you. No need for the :banana::banana::banana::banana:
Yes you have effects that put EAX to shame. But what you seem to fail to grasp is that they aren't available to Gamers in any form except with a X-Fi based card. If you think EAX is; "EAX effect set is nothing more than EQs, reverbs, echoes, and modulators" then you are the clueless one here. Xonar can't even do those measley effects you mentioned:rofl:
Example to prove my point. Some of EAX's biggest and best features are Transitions, Game voice that place players in and between locations. While outside the cave, you can hear other player/s as well as those going in and out of the cave simultaneously. Sometimes it can create sound perception overload for those not use to it. Experienced EAX 3+ users have been called cheats since they could tell the hallway from the next room because of EXCELLENT Obstruction and Occlusion. Upstairs instead of Down can be recreated where on the Xonar you can't fracken tell. NONE OF THESE ENVIRONMENTAL EFFECTS ARE on ANY other card=P Good sounds with NO EAX3+ effects are just plain. It's like watching Blue Ray in stereo.
Please stick to flaming LOE, because you don't know anything else. Look at my Sig and tell me about Low Quality Creative cards again?:rolleyes: "good quality sound card" what in the hell do you think the Prelude is? :rolleyes: EAX not only makes echos, it muffles, distorts, changes pitch, delays, decays, has low latency, creates elevation, distance and many other feats NOT pulled off by ANY none EAX card/s. It uses the best from Sensura, Aureal, EMU, and etc..
Xonar makes a great HTPC card as I said but NOT recommended for Serious Gamers.
That's funny, the DX EAX emulation works fine in games I've played thus far. You might have something else crashing your rig?
As for the poster who earlier said his DX "sounded like a Rice Crispies"...I don't get it. Mine sounds fine and I consider myself an audiophile. Some older pix of just a few of the high-end components I've owned over the years:
Mesa Baron amp -
http://usera.ImageCave.com/aztec447/Audio/05_3.jpg
http://usera.ImageCave.com/aztec447/Audio/07_5.jpg
Audible Illusions Modulus 3 pre -
http://usera.ImageCave.com/aztec447/Audio/11_9.jpg
Theta DS Pro Basic II -
http://usera.ImageCave.com/aztec447/Audio/18_16.jpg
I later got a Pass Labs D1 DAC, connected by AT&T fiber optic to a C.E.C. TL-1X transport. Look them up, they retailed for over $10k at the time.
Levinson No. 383 Integrated -
http://usera.ImageCave.com/aztec447/Audio/23_21.jpg
Here you can see the left B&W Nautilus 803. I had Sound Anchors make me a set of custom stands for them.
http://usera.ImageCave.com/aztec447/Drums/03_1.jpg
As someone else said here, most 'philes are not going to attempt to get "hi-fidelity" sound out of a fawking noisy PC playing questionable software, :doh: so my argument is: how logical is it to spend $150.-$300.+ on a PC sound card?? Most of the "high-end" cards out are gimmicky or over-built/over-priced and have very dubious benefit over a decent basic/mid-range sound card.
IMO don't waste your money. If you want to listen to great audio, then build a REAL audio system but don't expect miracles from PC audio coz it ain't gonna happen.
I'm sure some will disagree, so flame away boys!! :ROTF:
Many will give mad props to a very sweet system, also very nice Drums. I play Bass and have been learning Guitar.
I lived in the Audio Club on Rhine Main Airbase even though I was stationed about 100 miles away LOL! Two Air Force Dinks were Homies or from my home town, they visited me as well.
I bring this up because they sold B&W, B&O, Canton, Ohm, Denon, Merantz, NAD, many others and my favorite Phase Linear-Carver. The only thing left from my Hi-Fi is the Phase Linear Series II Range Expansion Noise Reduction unit. The 1000 Amp and Pre-AMP were only out done by the MAC equipment that they had but only Generals and Drug dealers could afford it.
Only running HPM-100 for Quality and CS-922's for loud parties.
Anyway, thanks for sharing those great Pics. I'm NOT one of those folks who think Audiophiles are wasting their time.
Mesa Baron amp... aahhh!...want it!...:slobber:
The Asus card looks good though! I like it - beautiful design!
